termigator
- Feb 5, 2009
- 721
Is it normal for the Flex to get real hot during usage? I seem to feel a lot of heat coming from the Flex everytime I use it. Is that normal?
make sure the backing plate is not coming into contact with frame nor the felt like material under it.
If you plug will not fit tight in your extension..thats your problem...the worse the connection the more the machine has to draw...so it heats up..a bad plug causes resistance....
get a contractors grade 12 guage cord..12 should be fine if your only needing 25 feet....but..I would go the 50 foot for the future ...never know
Al
I don't need 50 ft. Actually that will get in the way. I'll probably try 25 ft. or less. The Flex's cord is already pretty long too. Thanks for the feedback.:cheers:
You should oil the felt ring anyway. I apply a lithium grease to it every couple uses.I would really like to hear from someone who knows (possibly someone at Autogeek) whether or not this is normal, and whether or not oiling the felt ring and/or gears in the housing helps to alleviate the heat.
