Hot water pressure washer questions
hymato
My job has this washer for cleaning the http://www.amazon.com/dp/B000MD34I0/ref=nosim/?tag=electronicssh-20
My question is at what temperature will the water start to remove the wax? I only use 80f water on paint from a few feet away as its really high pressure. And I turn it up to 150f for rims and wheel wells. And what would use guys use in the chemical injector I'm currently using DP foam wash.
Spoke with some other people on another website and they said hot water will remove the wax but no one is sure at what temperature. It was decided that anything less than 90F 4 ft away since this is a pretty powerful washer should not hurt the finish or remove wax. But let me tell you I cranked it up to 200f and boy did it clean my rims fast!!!
