How Aggressive is this Combo ??
AntC
Hey Geekers,
I Just ordered a set of the LC Cyan flat pads and Menzerna Super Intensive Polish PO83, is this an aggressive enough combo for scratches like these:
picture.php
Or do I need to get a compound like 105, or could I just wet sand with 2000 and then step to the PO83
Let me know what you guys think..
I would do a tangerine or white pad with SIP before using the Cyan.
It doesn't look that bad, but pictures can be deceiving.
Try least agressive first and work your way up.
Unfortunately they is no definate answer to this without doing a test spot. I will say that SIP and a cyan pad can remove some pretty heavy swirls. Use caution when removing deeper scratches as you don't wanna wear the clear around it too thin. Unfortunately some scratches are just best left alone or just lightly polished over to round over the sharp edge and make it less noticeable.
Give it a try and you'll know! Test spots the only real way to know anything :)
+1
