How Agressive can I get with a scrub Ninja - Best Advice for Steering Wheels
chefwong
Active member
I have a clean steering wheel - fairly well maintained from new . It's just not matte black but it's a satin black---PATINA......
I suppose hand oils are in-evitable even after cleaning.
After a stronger cleaner, it does feel more -matte- and does look a bit more flat black but that only seems to last for a hot minute
Primarily use Interior Cleaner on it and have tried LM Strong Cleaner and it didn't appear to make that much of a difference.....
Maybe it is as good as it will get.....and I did use my Scrub Ninja once - light pass as in my mind, I am very minu-tia-ely micro-abrading it.
Maybe I'm leaning too much on the less aggressive side too much
Does anyone have a special technique to get a steering wheel back to bone stock clean.....
As I get older, I'm a bit more conscientious about how I spend things, but I might do my usual route of buying a brand new one and flipping the slightly used forsale.
Ha, it's the OCD
Ha, it's the OCD
Are you a smoker?
My father's steering wheel is permanently glossy, it's been abraded over several years and the nicotine from his hands has caused a sticky residue. Over the years, I've tried multiple different products and tools, from a mild alkaline interior cleaner, strong leather cleaner from ColourLock, even APC, teamed with either a scrub pad, medium stiffness leather brush or the TRC VLB. None have removed that sticky/shiny appearance. In fact, I'm now at the point where I'm removing the black dye. Do I continue hammering down on it, removing more and more dye, in turn make it look worse and worse? Or just mildly clean it and move on?
So yes, you can go too far.
Are you a smoker?
Put a steering wheel cover on that one, get him one of the fat RM Williams leather ones, less than $30 normally, and replace it every year.
Nah on smoke. It's not glossy but just has a slight sheen-satin-eggshell too it.
I would **love** to get it to 0 odometer grey flat black.
Have used the Scrub Ninja once on this steering wheel with LM Strong Leather Cleaner. Scrub Ninja was not scouring the surface....I just lightly scrubbed it as I still have reservations on whether is is abrading it on a micro level.
I know some like the scrub ninja but I think it's too abrasive for most situations.
That’s where I come done. I’d rather have some gloss than ruin a steering wheel. That said I use a multi step cleaning process so,d by Ron Keough (leather doctor) test I’ve always had great results with.
