Maybe Eric doesen't polish 14 hours every day, but that doesn't mean he is not qualified to give good advice, as Eric is very knowledgeable :xyxthumbs:
I'm not quite clear as to why you think it was ok to rip into a member on this board, a respected member at that.
Your logic is flawed heavily. Why in gods name would anyone, after 14 hours of hard work, break out a practice hood and start to practice![]()
That would be like the Pittsburgh Steelers leading Super Bowl XLIII with 4:32 left in the 4th quarter, and they call a timeout to do a practice play??? Where are you coming from?
Now I know you'll come on here and rebut, cause that's the kind of person you are. You think it's ok to rip into someone because you think you are better than they are and it makes you feel good to put others down?
"Eric is not qualified to give advice because he enjoys practicing"![]()
You know what I think, I think you're the one whom shouldn't be giving advise. You clearly belittled a respected member of this forum, and now you are making a very poor attempt to justify your actions. What a sad state of affairs. I didn't want to post this, but it needed to be said.
I won't be clicking back on this thread. I've said all I'm going to say. I'm sure an admin will handle it from here.
I wouldn't call myself an expert, but I have used the rotary quite a bit (production body shop) and my own cars a bit. I have had somewhat descent results and some bad ones..
One of the most important things imo is trying to center the pad best as possible on the buffer. Also as mentioned the finishing step is key including pad and polish.
Actually your step after the compounding/correction step is. That is where you want to clean everything up. On the finishing step you want as little defect as possible.
Fly Bye, do not use the Steelers as an example, they are that good, they do not need to practice. Six super bowls says it all. :dblthumb2:
