Well, ATM I have a flex, PC, GG 6" and GG 3", as well as a dewalt rotary and a makita rotary.
If I had to pick one for a beginner starting out it would be the GG 6" but plan to grab a smaller backing plate with it so it can do double duty. IMHO the GG 3" is underpowered, and while the PC is an excellent stand in for the GG 6" the modest bump in power and the warranty are a nice bonus.
The flex and the rotaries will correct faster, but will also be more aggressive than is needed in many cases not to mention their larger sizes are a little harder to work with in some tight areas.
+1,Same as above.:xyxthumbs:everyone should own at least traditional style DA, with that said pick up a GG6 and a 5", 3.5" and 3" DA backing plates with corresponding pads...
It's a good tool for a newbie, will take some more time, but I guarantee you it'll be a very pleasure time. If you're only working on your own car, and time is not an issue, you will be glad to use it.
However, consider the GG6 which people say is more powerful (I mean, on real use, because specs are obviously higher as stated), so you can do ~more if your paint is on hard side.
Grab a 5" backing plate, and a 3" backing plate, I'd go for the 5.5" flat pads from LC or, why not, 5.5 CCS pads, they are good as well.
You may want to get 2 Microfiber cutting pads as well (meg's are great) in 5.5".
If you're going for the GG6, or any other PC style machine, read everything recommended by Bobby.
5" plate and 5.5" pads are the WTG on those polishers.
Even if later you order another polisher (like a Flex or Rupes), you can use your PC/GG/etc for spots with smaller backing plate and pads.
Looks a good way to start.
Good luck,
Kind Regards.
