That's great information thanks much! Good old Mike, seems to pop up everywhere....:xyxthumbs:
There's a lot of young guys in SoCal that bolt on carbon fiber components but never maintain them as as a result we had a lot of cars come to the TNOG's and Saturday classes with extremely oxidized carbon fiber.
Here's what I've learned over the years from interacting with a number of people in this industry including the mold release industry and for what it's worth I wrote all the label copy, technical bulletins, application bulletins and a flow chart for the Meguiar's Velocity Liquid Polymer Mold Release System.
There are two general categories of carbon fiber components, there is straight resin and coated, straight resin is just that, it's either a part made with polyester resin, or an epoxy resin, I've been told that neither of these types of resins can have a UV inhibitor in them and this is one of the reasons why straight resin carbon fiber components will oxidize easily and readily.
Coated carbon fiber components are just that, the have a urethane clear coat sprayed over them and just like your car's paint has UV protection in it, the coating sprayed over carbon fiber has UV protection. This prevents the polyester or epoxy resins from readily oxidizing or fading. The clear layer prevents the resin from oxidizing because it seals it so moisture and oxygen cannot interact with the resin itself, the UV protection probably has more to do with protecting it from fading or failing from exposure to UV rays. This is just conjecture on my part and it would be great for a real expert from this industry to chime in.
But an analogy would be similar to what I wrote in this article,
The practical differences between single stage paints and a clear coat paints
And the effect of age, exposure and wear-n-tear to the two categories of carbon fiber components is similar to what we see with single stage paints and basecoat/clearcoat paints, that is single stage paints will oxidize readily while basecoat/clearcoat paint systems don't normally have oxidation issues, just swirls and scratches.
As others have said, using quality automotive polishes and waxes should work well to maintain the finish on your new components. The key is to find something you like and use it often.
The reason we had so many cars come to our Saturday classes and TNOG classes with severely oxidized carbon fiber was because most of the owners of these cars were not into detailing, thus no regular maintenance, just exposure to the SoCal sun all the time...
