Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How do I prime a Rupes Foam Pad on a Rupes Polisher?
I get asked this question a lot and I see it asked a lot so here's the answer.
Instead, you KISS or Keep it Simple Simon and simply apply 3 drops about the size of dimes on the face of the pad like this,
This is ESPECIALLY TRUE for the Rupes Blue Coarse Foam Cutting Pads as they have a very large open cell foam structure and if it's very easy for any excess product to sling out and off the pad and end up as splatter dots all over the car and even you if you over use the product.
From this thread,
Mind Blowing - Rupes Blue Foam Cutting Pad and Zephir Gloss Coarse Gel Compound
Here's a tip...
When you go to add fresh product, don't add it to the same place you previously applied the product. Space out future drops of fresh product to different areas on the pad.
Interesting Pattern Develops
I thought this was very interesting, it's a picture of a Rupes pad after placing three dime sized drops of product on a clean, dry pad and then buffing just one section of single stage paint.
Look at the pattern created by the product, it shows how the product settled out under use...
The below pictures were taken from this recent show car/race car we buffed out...
Pictures: 1966 Orange Chevy Nova Super Sport Extreme Makeover
Here's an excerpt...
Rupes Bigfoot Orbital Polishers
First we tested the green medium foam pad with the Blackfire SRC Compound.
Key Points.
No need to prime pad, simply place product directly onto the face of the foam pad, place the pad against the paint, use a medium speed to spread the product out then begin making SLOW overlapping passes with just a little more than the weight of the tool for downward pressure.
Triangle Pattern
Now look at this crazy patter created from three dime sized drops of product after buffing out one section of paint.
And yes... the car came out nice using this simple technique to get the product onto the pad.
Before
Question: How do I prime a Rupes pad on a Rupes Polisher?
Answer: You don't.
That is you don't prime a RUPES pad with RUPES compounds and polishes the same way you prime pads for other dual action polishers.
Answer: You don't.
From this thread,
Here's a tip...
Key Points.
Triangle Pattern
Before
