klumzypinoy
- Jan 30, 2007
- 3,265
How do you remove those shoe scuff marks on the bottom of the door in the interior of the car? It's so hard to avoid it, but it's hard to take them off. What have you used that took them off?
orngez said:imo...the best way to remove shoe scuffs is to use a light swirl remover on a mf pad...it depends on the material it is on...obviously not on smooth plastic...but on textured plastic you should be okay...bug and tar remover also usually does a good job as well...
Nuke33 said:I really want to try that magic eraser but I hear they have fiberglass in them and you can do some damage but IDK
nick19 said:It's like a block of sand paper... I hate them..
ltoman said:woah - glad i have been forwarned!
Cheetah said:I don't think it's like a block of sandpaper at all. I use it on stains and scuff marks. It works great and is cheap. You wet it with water and it becomes soft and then you wipe. I used it on my wife's steering wheel because there was a ton of grime on it. It took 30 seconds and looked like new after.
ltoman said:you can use magic eraser. i heard it works. ...
clambros said::iagree:
(used it on both my cashmere interiors .. no issues and works like a champ !)
