Audios S6
Active member
- Oct 12, 2011
- 1,634
For any to consider or refute.
Most of these coatings are moisture cured. I take that to mean they are using the H2O in the air as part of the reaction. Since we think of these as a SI-O bond, I have to also assume it is taking the oxygen from the H2O and the hydrogen ends up as part of a volatile compound (maybe an alcohol of some kind).
So there is certainly the potential that you are adding to what is in the bottle as part of the chemical reaction. It's also possible that the reactive molecule is larger in it's bottled form than after the reaction. It's also possible that the chemical structure is a matrix rather than the linear molecules dispersed in solvent in the bottle and literally builds itself larger on the surface just due to the geometry.
This is all speculation and without the manufacturer's chemists or some other independent chemist dropping by to enlighten us, it will remain speculation. But does provide an explanation for how your tiny bottle can grow when exposed to air.
