MobolWerks
- Feb 9, 2010
- 168
- Thread starter
- #21
You are polishing, not compounding. First of all, the DA you are using was pretty minimal "cutting" ability (the amount of defects it can remove - which also means you can't remove much paint or clear coat).
Second, you are using a white pad, which has very little "cutting" ability as well, so really, all you are doing is maybe removing .25 - .5 Microns, and that's only if you're manually shaking the crap out of the DA while polishing - shaking it gives it slightly more "cut"
I would not be to worried about your procedure
hope that helps
hope that helps
