Dano shine
- Mar 18, 2018
- 108
I started using only two pads and the results weren’t good so I took Mike advice and now I use 9-11 pads per Vehicle
Time is money!!
Time is money!!
I think to a certain degree this depends on whether you are using open cell or closed cell foam. Theoretically, closed cell foam leaves more on the pad surface than an open cell pad. Also, it seems that thicker pads absorb more product and get heavier than the thinner pads. It also depends on the particular product and the lubricants in it.
Maybe theoretically but..... I have used a ton of closed cell pads in my lifetime. They still become wet and less effective at the same rate as open called pads. Also closed cell pads wear out much quicker, so swapping them frequently will help lengthen the lifespan of the pad.
Did not work so good with foam because it just pushed the crud into pad
