Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
How many times can I correct my car's paint? (before going through the clearcoat)
Anytime I get questions via e-mail, a PM or a FB message I prefer to invest my typing time where
A: It's easier for me to share links, pictures and videos.
B: More people can read and thus benefit from the information. (no just one set of eyeballs)
The reality is, most people that contact me found me via an article I've written or a reply I've written on this forum. The thing is, instead of figuring out that the whole reason they are contacting me is because they found me via an article or answer I wrote on the forum that they to should bring their question to the forum because not only will that help them.... but it will help a future "them". If I answer everything in a private e-mail or other touch point, no one would find and contact me. It's a cycle or pattern that repeats as long as everything is shared in the public domain.
The above is kind of wordy but re-read it slowly and it will make sense.
So I get an e-mail asking,
Hi Mike,
I am an amateur "detailer"/weekend warrior and would hopefully like to progress further down the line to dealing customers cars. I have only been doing this sort of thing on my own car for a couple of months so still have a lot to learn.
I have been lurking on the megs forums but am not actually a member on there (I may have to create an account as the forum is amazing).this is where I found your contact details, I hope me sending this question via email is okay with you.
My question is mainly regarding compounds and polishes. I don't possess a DA or rotary polisher so everything I do is done by hand.
The products I have in my possession are mainly AF (autofinesse) and meguiars. My car is a 2012 ford fiesta which clearly hadn't been looked after paint wise by the previous owner (lots of small swirls and some surface defects).
A month or so ago I followed a full wash, chemical decontamination, clay bar, polish and wax session. The Polish I used was tripple by AF. as far as I'm aware this contains diminishing abrasives, fillers and a small amount of carnauba wax. I followed this up with one coat of megs liquid wax. The finish looked great but has slowly started to degrade due to the thin layer of wax I laid down wearing off due to weathering.
I would now like to compound, Polish and wax to give a more permanent finish to my paint without solely relying on the fillers and glaze in the Polish so if the wax does wear off I can just top it up without going back to the polishing stage. The product I have in mind is megs ultimate compound.
My question may be a tough one to answer due to many factors but......
how often could one safely compound/polish the car before damaging clear coat?.
As I say, I will only be applying these with a foam applicator pad by hand. How much paint is removed from the clear coat following a compounding/polishing session? Whether this be by hand or machine.
Please excuse the lengthy email, this has just been bugging me.
Thanks in advance
John
Great questions John,
First, take a moment to read through what I wrote here on this topic in 2009
https://www.autogeekonline.net/foru...how-many-times-can-you-buff-5.html#post268066
Here's the answer to your question and the BIG PICTURE point of view - you're THINKING is wrong.
Don't think like this,
Instead of wondering or asking how many times you can compound or correct the paint on your car before you buff through the clearcoat?
Think like this!
After you polish and wax a car, STOP DOING THINGS TO THE PAINT THAT WOULD CAUSE YOU TO HAVE TO COMPOUND THE CAR AGAIN.
For example, after you correct, polish and wax or seal or coat the paint, do do things that put scratches back into the paint - then you won't have to correct the paint again and that makes your question a moot point. Of course with normal driving and thus normal wear-n-tear you will get light or SHALLOW swirls and scratches, even I get this with my cars and I'm super careful, but I don't need to COMPOUND the paint to remove these I can stick with a very non-aggressive fine or ultra fine cut polish.
Make sense?
As for working by hand, take the leap and move up to machine polishing. I've been teaching detailing classes for 31 years now and giving this same advice for most of these years and I've never met anyone that REGRETTED buying a simple 8mm free spinning orbital polisher as their first polisher to get into machine polishing.
In fact, last year I wrote an article JUST for this topic and just for people like you. It's JAM-PACKED with helpful information plus a video that will show you how to use this type of tool and keep you safe but a lot faster and a LOT MORE efficient at polishing paint and then your wax or sealant will last longer plus the car will ALWAYS look better.
This is the 2nd time I've shared this thread on the forum since 6:00am this morning...
Here's what you need to get into machine polishing - Recommendations for a beginner by Mike Phillips
And as far as Meguiar's Ultimate Compound goes, it is a very good product. Check out this article,
Meguiar's Ultimate Compound History
Hope that helps and feel encouraged to join our forum, this is where I answer questions. Email is okay, but the forum is powerful.
Click here to join the AutogeekOnline.net car detailing discussion forum - THE best forum on the Internet
Hi Mike,
Thanks in advance
John
Think like this!
Make sense?
