Are you doing a full correction? If so post pics when done
A full correction was done. As were some terrible pictures...apologies in advance.
We are revisiting the scratch.
1st time polishing Porsche paint. I found it very soft as others have described. My Sonus Wunder towels were causing some marring when removing compound, switched to some 600GSM.
The water spots and rids fought my initial attempt with FLEX 3401, Wolfgang Total Swirl Remover (WGTSR) and an Orange CCS Pad. Ended up using M105 on an Orange CCS, followed by WGTSR on a White CCS, followed by Wolfgang Finishing Glaze (WGFG) on a Blue CCS Pad.
Hazy after M105
Left is after WGFG. Right is after WGTSR
The slats on the engine cowl were difficult to tape off and hard to polish without the housing of the buffer hitting the slat above. I ended up using a 3" Meguiar's Cutting Microfiber on an old Porter Cable 7424 with an extension that works with a backing plate for a rotary. I have now read in the Forum that you can just tape one...polish one...tape one...polish one. This strategy allows you to effectively protect the back lip of the slat above when polishing the one below it.
After M105
After WGTSR
The inner barrel on these wheels is huge! Sonax Fe and a small Daytona brush knocked it out. The
Recessed Lug Nut Cleaner works, but is a pain in the neck. The foam continually gets pushed up on the holder and has to be put back in place by hand. I would not buy this product again.
I finally found something to use my 1/8" 3M tape for. I also used it around the sunroof, but I think it would have been easier to just tape it twice.
Since this I have purchased some cheapie wheel covers from Harbor Freight. I would suggest to everyone that they are a great tool and a time saver.
Exhaust was cleaned up with 0000 Steel Wool, Optimum Metal Polish (shake really well) and a microfiber cloth...shoe shine style.
Beading shot after polishing, before LSP. That WGFG seems to have a lot of oils in it. You can work it endlessly, but is can be difficult to wipe off. I used Wolfgang Deep Gloss Paint Sealant, so I did not do and IPA or Eraser wipedown.
Tires wearing two coats of Optimum Opti-Bond Tire Gel. Diluted 1:1 and applied with sprayer. I now prefer using it straight.
Maybe I am an "AssMan"
