LegacyGT
- Aug 13, 2010
- 2,090
My wife was unfortunate enough to park next to a landscaped area at the gym and her car got nailed by the sprinklers on a very hot / sunny day resulting in some extremely bad water spots. The water in our area is also very hard, I measured it once and it was off the scale in terms of dissolved minerals.
I knew that this bad going in because the windshield was physically etched from the water spots, and ultimately required polishing out with Power Finish on white to remove the spots. The car (not including the glass) had been treated with Opti-Coat 2.0 about a month prior, so I thought this would be an interesting real life test of the ability of OC to protect the paint.
I had to wash the car at night because our heat indexes have been out of control lately, so last night I drug out the halogens and gave the car a quick wash with Optimum Car Wash (mmm blueberry) with a MF mitt, and the regular two bucket method.
A note on the pictures: These pictures have been re-sized to strike a happy medium with the responses from forum members. You can view larger sizes in the following gallery: Prius Opti Coat
Doesn't look too bad right?
Let's see it from a different angle:
:nomore::nomore:
A picture of the Opti-Coat beading very well before the wash:
And the results of just a simple wash and no other treatment on the water spots:
As you can see they have been 80% removed, and there are still a few spots that need attention. Going with the least aggressive method first, and simply washing proved to be very effective at removing the water spots. For a point of comparison, the water spots on the windshield were much more stubborn and required polishing to remove, indicating to me that the OC is providing a very tough layer of protection. Next I will hit the hoot with some vinegar and see if that removes the rest of the water spotting.
Till then.
:nomore::nomore:
Till then.
