Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
How to ceramic coat Matte Flat Graphics with PBL Ceramic Matte Coating
Pinnacle Black Label Ceramic Matte Coating
Are you a tick scared to work on matte graphics?
You're not alone.
Anyone that knows anything about matte surfaces, be they vinyl graphics, paint or plastic, knows that you normally don't get a second chance if something goes wrong. So it's only normal to be a tick hesitant to do anything. Instead, most people play it safe and do nothing, hoping the matte surfaces on their car will simply look good a long time and last a long time. Reality is - it doesn't work that way, at least not if the car in question is a daily driver. Left unprotected matte surfaces will go bad.
Here's the good news!
As long as you're careful, use clean microfiber tools like applicators, wash mitts and towels, plus be pro-active in maintaining a protective coating on the matte surfaces, it's completely safe to work on matte graphics, matte paint and matte plastic components.
Here's an example. While this is a Garage Queen, never really driven in inclement weather, the matte graphics and matte paint on the rear deck spoiler were not aging well and looking neglected. After washing the car when I was cleaning and protecting the vinyl top,
Afterwards I addressed the matte surfaces using products from Pinnacle Black Label.
Process
Step 1: After washing and drying the car, I gently wiped all the matte surfaces using the Pinnacle Black Label Surface Prep Spray. The PBL Surface Prep Spray gently removes any unwanted contaminants to leave a clean surface behind perfectly preparing the surface for the next step, applying the ceramic coating.
Step 2: Using a blue microfiber coating applicator I applied the PBL Matte Ceramic Coating using the normal overlapping crosshatch pattern.
Step 3: Within minutes of application I used a flat weave, edgeless microfiber towel to level the coating and remove any excess coating.
WORK CLEAN
The key thing about working on any matte surfaces is to ensure everything that TOUCHES the matte surfaces are clean, soft and uncontaminated. If you haven't seen my video or read my article on this topic, click this link.
Here's some pictures showing how easy and safe it was to install the PBL Matte Ceramic Coating and I did this in about 20 minutes or less.
I started with the vinyl graphics at the front of the car. This is the most looked at area of the entire car, the front of the hood. It's important to be careful so you don't LIFT the TIPS of the lettering.
When wiping, be sure to fold your microfiber towel 4-ways and keep the towel flat to the surface and use a gentle touch.
Go slow when wiping the lettering...
Next is the louvers for the hood scoop fresh air intake...
In order to do the entire area at one time, which means working on both sides of the car, I worked fast but was also very careful.
After application, I gently wipe using a clean, inspected microfiber towel to both level the coating and remove the excess for a UNIFORM appearance.
That looks right...
Next I move to the back of the car to work on the read-deck spoiler...
The application step will make the matte finish look splotchy with patterns from where you wiped. Have no fear...
Softly wiping the spoiler levels the coating and creates a beautiful uniform matte finish that is now protected.
It's so much better to do something versus do nothing. The key is using quality products specifically formulated for matte surfaces and just as important, make sure all your microfiber tools are clean, soft and un-contaminated.
On Autogeek.com
Pinnacle Black Label Ceramic Matte Coating - $100.00
Pinnacle Black Label Diamond Surface Prep Spray 8 oz. - $20.00
Blue Microfiber Coating Applicator - $3.00
Cobra Storm Gray Edgeless Microfiber Polishing Cloth - 12 Pack - $20.00
You're not alone.
Process
WORK CLEAN
That looks right...
On Autogeek.com
