Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
How to Clean & Coat the INSIDE of your car's wheels
For those of you that like every part of your car detailed to the max! Or for those of you that offer complete wheel and tire detailing...
I had an axle flange gasket leaking on the Corporate 14-Bold Rearend on my truck so I had to replace the gasket. I also wanted to rotate the tires from front to rear. I also wanted to coat the inside of my BRP Rims and seal the inside of the tires with TUFF Shine Tire Clear Coat. I also wanted to check and re-torque all the lug nuts, just to make sure... So I decided to knock out 5 projects all at once and then share it all here on the forum.
Undoing the other guys botched assembly work
Keep in mind, I bought this truck this way, that is some Billy Bob used high heat silicone when they assembled the axle to the hub. First you don't need to use silicone when you install a new gasket and torque the axle shaft down properly and second, when you do use silicone you use a thin film, not gobs of the stuff like you see here.
I covered the disc brake assembly because I'm going to be spraying solvent and I don't want to transfer anything onto the brake discs by accident.
No picture of this but I did stick small tube on the end of our Shop-Vac and sucked out all the dirt and silicone out of the threads where the axle bolts go and then swapped them with solvent followed by oil using the foam detailing sticks we sell on Autogeek.net
This is only half of what came out of the threaded holes..
Nice...
Okay, someone else's mess cleaned up and now it's time to get the back side of the wheels and tires cleaned up.
That's ugly, even if you don't see it because it's on the inside of the truck it's still ugly...
Sunny Saturday in Sunny Stuart, Florida... I'm going to use Detailer's Wheel Cleaner to clean both the wheels and the tires.
Ugly...
Ugly....
I sprayed and scrubbed the back of the tires THREE times to get them pretty clean. I'm not aiming to win a car show with the back of my tires so I'm not looking for perfection but at the same time I want them clean and I want the TUFF Shine Tire Clear Coat to properly bond to the rubber.
Dum de dum dum dum.... could be at the pool...
Autogeek carries dozens of car detailing brushes, to clean just about any shape, size or design of wheel...
This brush is thick but with a little twisting I was able to get it to bottom out inside the wheel barrel to get it really clean...
Okay, after sweating for about an hour both wheels and tires are surgically clean...
Nice...
Ugly...
Ugly....
