DFB
- Aug 12, 2019
- 5,846
- 5,042
Here is the picture, I hope it is good enough, if not I can try next time I am cleaning them. It's not the rim rash![]()
Looking at the image, do these wheels have a matte finish? I've found matte wheels don't repel brake dust like normal painted wheels, so it tends to embed into the finish. On matte wheels, the ceramic coating manufacturers recommend two layers being applied for this reason, which helps seal up the finish prevent/slow the rate of this staining from happening.
Sadly, quite often a good wheel cleaner or iron remover won't remove this staining. And being matte, you can't really polish either. As others have mentioned, at the very least start by using an iron-remover type wheel cleaner such as Carpro WheelX, NV Purge or Sonax Full Effect, you might get lucky. If you do go the acidic route, just be very careful, its probably not something I would recommend on matte finishes.
As for the gloss black wheels, they certainly need to be polished to bring back the clarity of finish. I'd then coat them to make cleaning easier, and therefore safer.
Good luck.
