AIO's are similar. Dawn actually does a decent job of getting out the bulk of the sealant. The last time I tried Citri-solv (similar to Citrol). That worked real well. I don't know if it was just good on this product (I think it was the new Black fire AIO). I'll have to try it a few more times to get a better idea. I also know I've read about guys using mineral spirits with good cleaning results.
My take on the whole pad cleaner argument is you could use the above-mentioned methods (or others) and just do a final rinse out with pad cleaner and be ok. No basis for this other than it makes sense to me.
OPC undiluted can break down WGDGPS some BUT the majority of the sealant will be removed if you wrap a towel around the pad and squeeze the pad as hard as you can. Flip to a clean spot on the towel and continue doing this until the majority of WGDGPS is removed.
This method of transferring the sealant from the pad onto a towel will remove up to 90% of the sealant.
Put it on the rack to dry and either throw away the towel or wash it.
If you don't believe it's as easy as this, next time you apply a sealant just try wrapping a white paper towel around the pad and squeeze. You'll see just how much of the sealant transfers onto the paper towel.
I have used the Wolfgang DGPS and I love the product. It does stay in the pad after many hot water rinses but I have had success with McKee's 37 polishing pad cleaner. It is a great solvent that removes the product and leaves a clean pad. Make sure that you wear a mask when you use it. The spray can be pretty strong.
Thanks for the tips. Will try using a towel to clean the pad next time I apply. Will also dedicate the pad to WGDGPS.
Is it true that something like 3D towel kleen or the mckees pad cleaner I use that is quite strong can not break down wgdgps? I thought these products were supposed to do that?
I have used the Wolfgang DGPS and I love the product.... Make sure that you wear a mask when you use it. The spray can be pretty strong.
