How to correctly use an AIO or Cleaner/Wax by Mike Phillips
Mike Thank you for the thread.
It makes sense. I have been using an AIO like a wax; I'll try using it more like a compound with more pads.
Thank you you again.
Glad it helped, I wrote this because I think there's a lot of people that are possibly using AIOs the wrong way and then perhaps disappointed in the results they get?
Sometimes the little things are the big things...
Just did this yesterday with BF One Step!! Love the stuff!
Jay
I topped it with Wolfgang DGPS...it was a easy on easy off day!
Ha ha....
I told you it was good.
If I could have my druthers - Id druther use this for every detail. So much easier to work with and wipe-off than a compound or polish.
The problem is everyone wants a coating now days.
Ugh....
Not everyone, Mike. :D
May be a silly question but why top a product which leaves a sealant (BF) with another sealant (DGPS) ?
Wouldn't that prevent the DGPS from bonding to the paint ? Will a sealant bond to another sealant ?
I have always topped HD Speed with other sealants/waxes/hybrids, and have never had an issue, Rob.
The thinking goes like this,
After using a ONE-STEP cleaner/wax, or cleaner/sealant or cleaner/hybrid or AIO by any other name, you then top the results with a product that does NOT have any cleaning aspect, thus you're laying down pure protection.
The first product, while it was cleaning or abrading, somehow at the same time it's protecting. At the same time it's protection, it's cleaning and/or abrading.
Everyone always wonders,
How can a one-step product do three things at the same time?
The answer is, it cannot do all three things as good as breaking each process down into it's own step using dedicated products, thus a one-step does three things but never as good as actual doing the three things,
Compound
Polish
Protect
That said - a good one-step does in fact do a good job within its limitations. I use the one-step process all the time and in fact it is my favorite and preferred way to detail a car UNLESS the owner of that car specifically wants a paint coating and then a product that contains a wax or sealant cannot be used.
There's two recent threads about this, here's one,
https://www.autogeekonline.net/foru...gang-profi-ceramic-coating-2.html#post1676961
And here's my article on what is called, topping from 2011,
Topping - Definition - How to Top also called Topping
Another great question and a common, common, common question that I've been answering for 18+ years now.
The first time I shared the answer from 2005, see post #6, the "quoted" section after this picture,
Do Glazes/Fillers affect the bonding of NXT?
And the updated version after I came to Autogeek I re-wrote or plagiarized myself, in 2010
Miscible and Immiscible - Wax and Paint Sealant Bonding
And while the original context for the answer to the question of whether a wax or sealant will bond to paint after polishing but without chemically stripping the polishing oils off the paint, I do believe the same chemistry and logic applies to applying a dedicated wax or sealant over a one-step cleaner/wax or AIO.
Hope that's as clear as cyber-mud.
And in the famous words of Tom Mosca,
I've never walked out into a garage only to find out that overnight the wax or paint sealant I applied slipped off the car's paint and piled-up on the floor surrounding the car because it didn't bond or stick to the paint.
