How to find the bottle of spray to match the texture colour?
chris0147
Hi all,
I am looking for a bottle of spray to respray on the rocker cover.
I want to get the bottle of spray to match with the texture colour so it would not look horrible when I respray on it.
Here is the rocker cover:
Do you know how I can find the bottle of spray to match with the texture colour of the rocker cover to make it like this?
I have been told the name of the paint colour is called satin black.
I'm not sure if it is the right paint colour. How I can find out what paint it is and how to match the paint colour?
I have tried with C4 trim restorer and solution finish, but it doesn't work. It got faded when I wiped them off after few mins when I used microfibre cloth. I have been told that my rocker cover is made of structural composite material which I could not react to restore to the original factory colour. I am not sure if I have something wrong and I am not sure if my rocker cover is made of plastic or structural composite material. You may know it as you have a better experience than I do.
Would the heat gun help?
Any advice would be much appreciate.
Thanks in advance!
How much would a new cover cost? I think you might be trying to achieve something that isn't possible.
Don't laugh, but no kidding… Try PlastiDip. IF it can withstand the temperature range per manufacturers instructions (this I am uncertain of).
If you don't like the way it looks, you can always take it right back off. No harm, no foul. It gives a nice satin finish.
•Remove from vehicle
•Degrease
•Apply Solution Finish
•Top-coat with DLux
I have applied solution finish but it got faded when I wiped it.
I use Meguiars all purpose cleaner to remove the grease. Are they good or not??
Do you know if carpro Dlux would work for composite material??
Solution Finish is formulated to be
applied to properly prepared---per
its instructions---plastic(s) surfaces.
What type of composite is this
rocker cover made from?
I have got no idea. How I can find out what type of composite is made of??
However, I have been told by someone that my rocker cover is made of of structural composite material. I have no idea if it been made of structural composite material.
