OK, I have the foamgun on order. My initial soap will be Meguiar's Gold Class as I have a full gallon of it at home. Meg's suggest 1 ounce for each ounce of water.
My question is, how do I mix that in foamgun. According the description, there is a 1oz/gallon setting. Do I just fill the foamgun canister with soap and the setting on the gun takes care of mixing it correctly?
Some of the other threads have alluded to mixing a soap and water solution in the canister first. If so, then would I be using a diluted ratio based on the manufacter's suggestion? To clarify, if I put 1 oz of soap and 3 oz's of water into the canister, then set the gun to 1oz/gallon, am I really get a soap to water ratio of 1oz to 4 gallons of water?
I usually use about 3 oz's of soap in a 5 gallon bucket. I probably end up with about 2- 3 gallons of water in the bucket by the time the suds overflow the top of the bucket. I cannot wait to see how the foam gun works out.
