Odorless Mineral Spirits
Mineral Spirits are another option for chemically stripping an automotive finish, from my discussions with chemists on this topic, odorless Mineral Spirits should be chosen as the process for removing the odors is actually removing a lot of nastier substances through further refining of the product. Mineral Spirits will tend to wipe easier than most other options and leave a more clear finish.
Percent Volatile
When discussing Mineral Spirits, the idea has been brought up that Mineral Spirits may leave behind a film that could, like compound or polish residues, mask defects and thus defeat the purpose of stripping the finish after correction work. I brought this up with two of my chemist friends and they both said that it's not an issue, but if you want to be sure, choose a brand of Mineral Spirits that states the
"Percent Volatile" is 100%
Here is the MSD Sheet for the Klean-Strip Odorless Mineral Spirits. I have circled the "Percent Volatile" percentage.
Percent Volatile
Here's a
generic MSD sheet for IPA as I could not find one that was specific to the Walgreen brand, but chances are very good all quality brands of IPA are similar to the "Percent Volatile" figure below, which is
greater than 99% or
>99
Percent Volatile
FWIW
My colleague stated that Mineral Spirits will tend to penetrate deeper into automotive paints, but it's safer than IPA.
Again, DON'T chemically strip FRESH PAINT as it has not finished fully cross-linking, drying and hardening and you risk harming the paint.
All Purpose Cleaners and/or Degreasers
On the topic of using All Purpose Cleaners and/or Degreasers for chemically stripping paint, the consensus is that the more simple the product, (Products specifically formulated for this procedure or IPA or MS), are safer and preferred.
All Purpose Cleaners and Degreasers are more complex in their formulas in that they
contain more ingredients to give them the ability to clean or
dissolve a wide spectrum of substances like grease, oil, road grime, etc. It's this expanded ability to dissolve a wide spectrum of substances that make All Purpose Cleaners and Degreasers excellent for cleaning things like engine compartments but for this same reason makes them riskier to use on a delicate, clear coat finish where they can stain or dull paint.
Again, I wrote this article because it's a reoccurring topic on detailing discussion forums and I couldn't find any real substantial article on the topic or the process. I've done my best to make sure the information presented is correct to my knowledge.
Personal thoughts on inspecting correction work...
I tend to use a combination of all of the above, I don't have an allegiance to just a specific product or process, but instead which product I will use may depend upon what I'm trying to accomplish, or even simpler... what's closest to my hand at the time I'm working on a project.
Personal thoughts on removing previously applied waxes or paint sealants...
My personal opinion and habit is to use a light polish or paint cleaner to remove any previously applied waxes or paint sealants to get down to a fresh base.
Not only will a quality light polish or paint cleaner effectively remove any previously applied wax or paint sealant, it will also create a clear, high gloss surface perfect for application of wax or paint sealant. This is what I call working forwards in the process.
For those that are concerned about proper bonding of a wax or paint sealant to the paint due to any trace residues left behind, see my article,
Miscible and Immiscible - Wax and Paint Sealant Bonding
