JefriLay
- Feb 28, 2011
- 111
Hi all,
Recenly I've bought Porter Cable 7424XP and have used it several times, but sometime I find the PC stop rotating when the position is not flat. the questions are:
1. How to hold the PC while working with it?? I've removed the handle and put tape around it. so the cover won't escape easily.
2. Why sometimes it is stop rotating? For example if I apply M80 with the speed set to 5 and pressure 15-20 pounds sometimes the PC stop rotating. I've put a mark on the backing plate also.
3. When it is stop rotating, is it still polishing because the PC is just shaking when it is stop rotating?
4. How to properly run a PC (in my cases) on complex surfaces?? Such as edges or the transfer from the top of the car to the side of the car.
FYI The backing plate I use now is 5.5" and the pad is 6".
I think that's all for now. Need responds as many as possible.
Thanks in advance guys for the advice and information.
Best regards,
Jefri Lay
Feed back please
Best regards,
Jefri Lay
Feed back please
