Hello everyone!
I've read a few threads on wetsanding. Got some tips from it.
As the title says, How would you completely remove 2000 grit marks if this were the finest grit you had?
I'm using the rotary and LC CCS orange pad with Menz PG (the old one).
I must say that I'm having a hard time knocking the 2000 sanding marks with the orange pad. (maximum speed 3) btw, the 4' inch pad seems to do a better job than the 6.5 pad correcting scratch and sanding marks even if it doesn't completely remove them.
The finest grit here I can get is 2500 (mirka). it'll be in a few days though.
Feed back please
Do I need to increase the speed?
would the LC wool polishing pad be a better option at getting rid of the sanding marks?
Also, how long can you use a sanding paper?
looking forward to hear from you.
Many thanks.
:xyxthumbs:
Zaid
Feed back please
Many thanks.
:xyxthumbs:
Zaid
