I noticed that you said your hood, trunk and roof all had the rough feel to them. I honestly wonder if some sort of overspray got on it...either at work or if a neighbor had their house painted or just in a parking lot where construction of some sort was going on near by...it would land more on the horizontal surfaces than the verticle ones and that would explain why everything else still felt super smooth.
The other thing I'm wondering is possibly tree sap...usually people think tree sap and think of it just sticking to the tree, but some trees (like ones i have here where i live) actually kind of 'spit' it if you know what i mean...lands all over the car...and if not taken care of and allowed to bake, depending on the type of sap...it could cause a big pain in the a$$ to remove...same as overspray.
The suggestions made were good as far as how to take it off if it happens again...but if you notice it again the sooner you try to remove it, the better. The sealant will help keep it from bonding somewhat...but it can only do so much against overspray/sap and other things that will bond to your paint.
Just my thoughts, maybe im totally off...but ive seen/heard of it happening before. Hope that helps some:dblthumb2:
you are most likely correct. certain types of trees literally rain sap all day long. if you see it in the right light you can see it falling from them sometimes on a hot day.
This sap is fresh and typically HARD, to it will make the paint feel like gravel. if they have been there for a while they can eat through the sealant. there is enzymes in the sap that can eventually etch into the clear coat.
I know i did a GMC truck that had this problem. it had been taken care of but this sap wouldnt come off with a washing, or clay bar. it had been there too long. i had to sand them off and then correct it. a very long process.
So, if you feel your paint is rough, try washing it ASAP and see if it feels better, if it doesn't clay a small area and see then, if it starts to get better then, its Most likely sap.
if you wash, and clay and its still their its either been there for quite some time or its something else.
Also if you feel the surface is rough, clay bar might remove it. but if the sap etched into the coatings at all the surface may still feel rough. what you are feeling then is the depression left behind where the sap was. try using a solvent to wipe the sealants and everything off the clear and see where you stand there.
For that reason if i plan to detail the exterior of a car i will wash it with something aggressive enough to remove waxes and other products. This was I know the paint is clean and what ever i feel is most likely a surface imperfection.
