How to remove a scratch from a headlamp
kevincol
I have a 2016 Corvette. Someone scratched my headlamp casing and I would like to know the best way to remove that scratch without adding swirl marks to the headlamp casing.
All the headlamp products I see are about removing yellow and clouding. Since the car is new, I don't have that problem.
So, looking for advice or product recommendation to remove the scratches that some ding-dong put on to my headlamp casing.
Since it is new you might just want to polish it some to try to reduce its appearance. If you sand to remove the scratch it may reduce or remove some of the factory coating. If the coating is removed it will cloud up or yellow quicker.
I say try a polish at first. If that doesn't remove it enough then try a compound. If you are still not happy with the results, then sand enough to remove it, compound, polish, then coat with something like Opti-Lens to protect.
Here is the picture of the scratch. It is at the front of the headlamp.
I was born in Bowling Green, KY. which automatically makes me a corvette fiend. I would hunt down whoever did this and scratch them up if you know what I mean!
I don't have a solution for you but badass and congrats on the '16 Vette!
Yes.... the XMas spirit has been with me towards the undiscovered culprit!
