HUMP DIESEL
- Dec 2, 2013
- 930
Mike,
What backing pads are you using on the Rotary machines? The white multi-sized ones?
HUMP
HUMP
Hi mike, for PC DA, what is your speed setting?
Mike,
HUMP
Mike, do I have to use a rotary buffer if I have gone over the car with 4000 paper?
I sanded with 2000 and then went over the it again with 4000.
Will the DA Buffer cut the 4000?
I didn't notice anything about wet sanding the taped areas. Do you do that by hand?
I noticed in one of your posts you mentioned using a 3" for edging first.
Do you do this for the body lines too?
I have tested numerous times and now have damp sanding kits available in 3 , 5, 6 inch discs for da sanding on my website djpavlica.com in stock and ready to ship.
An entire 3M system. No rookie here.
