Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
How How To remove Paint Transfer off your car's paint
How To Remove Paint Transfer
Paint Transfer is a term used to describe when the paint off of some other object is transferred onto you car's finish usually by some kind of accident.
My friend Rob is a Fitness Instructor at the gym I work out at and someone, somehow sideswiped his 2006 Ford Mustang GT and in so doing took off is side mirror and transferred some white paint onto his car's finish along with instilling some marring and scratches.
Luckily the damage wasn't worse!
Here's how you can remove paint transfer by hand using a light paint cleaner. For this example I'll use Pinnacle Paintwork Cleansing Lotion.
Pinnacle Paintwork Cleansing Lotion non-abrasive, it is designed to safely take off old wax, embedded road grime and pollution that washing will not remove. It prepares the surface for waxing by creating a clean, smooth, highly-reflective surface.
This is a very mild polish and because it's non-abrasive I'm going to apply and work it with a microfiber applicator pad, in this situation were using the nap of the microfiber as our abrasive along with the lubrication and cleaning ability of Pinnacle Paintwork Cleansing Lotion to gently remove the offending paint.
If you find Pinnacle Paintwork Cleansing Lotion is not aggressive enough, you can use Pinnacle Advanced Compound. This is a hi tech compound that uses the latest in abrasive technology and while it will finish down like a polish it's a good idea to follow it with a less aggressive polish like the Pinnacle Advanced Finishing Polish.
Place a small amount of Paintwork Cleansing Lotion onto the face of your applicator pad...
Next work the polish and applicator against the transferred paint putting a little passion behind the pad but don't push too hard or you could instill fingermarks just from the concentrated pressure from your fingertips...
After working the product for about a minute, stop and inspect to check your progress.. You can see most of the paint transfer has been removed but not 100% of it. Sometimes you many need to repeat the process a few times to completely remove the paint transfer.
After you've successfully removed the paint transfer you can apply a protective coat of wax or paint sealant or like I've done here, machine polished the paint and then machine waxed the paint.
Looks as good as new and now Rob's going to have the mirror replaced.
Thanks Rob for bringing your car to Autogeek's Show Car Garage!
Products Used
Cobra Indigo Microfiber Polishing Cloth
Cobra Microfiber Applicator Pads
Pinnacle Liquid Souveran Car Wax
Further Resources
How to use a hand applied abrasive polish or paint cleaner by hand
Paint Cleaners at Autogeek.net
Wolfgang Paintwork Polish Enhancer
3M Scratch Remover
Dodo Juice Lime Prime Lite Cleaner Glaze
Dodo Juice Lime Prime Pre-Wax Cleanser Polish
Duragloss PreCleaner
1Z Einszett Paint Polish
Four Star Ultimate PreWax Cleanser
Griot's Garage Fine Hand Polish
Liquid Glass Pre-Cleaner
Meguiars SCRATCH X 2.0
Meguiars SwirlX Swirl Remover
Mothers California Gold Pre-Wax Cleaner
Mothers California Gold Scratch Remover
P21S Gloss Enhancing Paintwork Cleanser
Poorboy's World Professional Polish
SONAX Premium Class Paint Cleaner
SONAX Paint Cleaner
Products Used
Further Resources
3M Scratch Remover
SONAX Paint Cleaner
