As I stated, I did it on purpose. I was just curious to see what would happen if anything. This weekend I plan to repeat the procedure and take pictures, using both a yellow applicator pad and one of my older ht pads if I have any left. I think I trashed them all.
I just want to give a heads up so no one else uses this on their pads.
I just rotate it into use next time I polish a vehicle. Put a finish polish on that pad and start polishing with it. When those finishing passes are completed I don't think there is still sealant in that pad.
Ive had good luck with the XMT Pad cleaner and using the Snappy pad cleaner. For the Snappy i scrub them in a 5 gal and leave them to soak in the solution for a few hours and it works great!
Paint thinner is the only thing that works to clean pads then follow up with water and soap.
It certainly is not the only thing that cleans pads. I wouldn't use paint thinner on my pads. What I listed above works great and my pads come out looking new after that process. Ocasionally I get a stain but the pads are certainly clean and ready for their next use.
I use a 5 gallon bucket with one large scoop of Oxyclean. Fill it about halfway with water from the hose to foam up the Oxy, throw the pads in and let them soak. They usually soak for a few hours but I have left them in the solution for up to two days (yep, forgot them). Wring out the excess and throw them in the washing machine using Charlie's soap.
They come out as new no matter what was on them including paint. Not once has there been damage or velcro separation. Pads used are LC 6.5" flat for the most part.
Oh good I have both of those. Just to be clear, you have used WGSDPS in them right? Because that stuff is crazy.
Polish is one thing but sealer is very difficult to remove. I use blackfire sealant and that is impossible to remove without paint thinner.I use the DP Polishing pad rejuvenator per instructions. You put a cap
full (comes with the product) per 3 gallons of water. I use a 5 gallon bucket with cover. I put in the water then add a cap full of the product
mix it up . It turns into a nice green liquid and then you soak your pads in for 15 minutes.. then I work and squeeze my pads by hand after they have soaked for a several times until I see no more polishing product come out of the pad then I let them air dry. They come out perfect.
Glenn
