great thread
I ordered the DP high performance glass restorer just the other day. Could this be used in place of the diamondite products to remove the pitting? or is the DP glass restorer only chemical cleaners designed to remove the water stains? (the water stains were really the reason for purchase)
Any pad recommendation for the DP glass restorer?
edit: just noticed this was in the diamondite forum. sorry. just trying to compare another glass polishing product that AG carries
Mike, have you ever used Rhodite? I noticed it's not in the store, so I wasn't sure if it's been tried or not. I've never personally used it but saw it on one of those weekend car shows.
Mike
I have the glass polishing pads and the Diamondite Restorer, what speed setting should I use? Wish I could find some of the Resurfacing Creme!
Mike is it possible to use any of this stuff with a PC DA polisher? (non XP) or a cordless drill that can be plugged in? I was going to buy a kit for drill use but a lot of them say to set to 1800 RPM for instance like you used on the rotary, but my drill just has a trigger and clutch resistance settings. I did recently inherit an old fully electric drill but I suspect it does not have speed settings either.
Sure!
If all you're wanting to do is to remove things like the road film, water spots and other gunk that builds up on the glass over time a PC or a drill will work.
For actually abrading glass in a way to remove things like scuffs and shallow scratches, you really need the power of a drill. I think I covered this in my first post of this thread.
Here's a feature I shot with Bryan Fuller on using a PC to machine polish glass using this kit. You can't see what we could see or feel in the studio but this truck has been parked outside since it was purchased new and before we could use it for the glass polishing feature I had to clean up the hood so it looked good on TV
How to clean and polish glass with Diamondite by machine - YouTube
The kit we used is not for removing scratches though... at this time we are out of stock of the Glass Resurfacing Creme. I sent out my only two bottles to the other two guys also posting to this thread with glass issues.
Which type of tool are you using?
What are you trying to accomplish?
OK, dove in this afternoon. Focusing on a test area, have hit it twice and am not making much progress. Mike, how much time did you spend on each section? My first pass I was obviously too delicate as I wanted to be sure I wasn't going to do more harm than good.
2nd run though, I spent a good 3-4 minutes on the same section with enough pressure that my arm was giving out (1500 rpm on the Makita). Results - still many pits, actually can't even tell if I put a dent in any of them. Do I just need to keep at it??
You need to get heat in there to work for you, without overheating it to the point of creating distortion or ruining your glass (any experts feel free to correct me if wrong). It's high speed and pressure, and it does tear your arms up pretty good if you have an office job (like me, haha). I have 3-4 passes on my windshield to remove the hazing, the glass was definitely warm, and I went through a lot of water and polish. If the pits are deep, you are going to have a hard time removing them.
I posted an update in my other thread a bit ago: http://www.autogeekonline.net/forum/diamondite/38072-swirls-glass-2.html#post565130
