davidc11291
- Oct 14, 2011
- 200
This is primarily a question about drying a car prior to lsp application, when a lot of water beads up on the surface and most of it won't just slide off on it's own.
Normally I use 1 towel to get the majority of the water then go over it again with a second towel to get that last 10% of moisture that remains on the surface. This means that with the second towel, I'm basically running a dry towel over an almost dry paint surface, which I don't like because A) it's time consuming, B) I go through 3-4 towels per vehicle, and C) I don't want to run the risk of marring the surface by pretty much buffing off every bit of moisture with a dry towel.
Do you get 95% of the moisture off of the car and leave the last little bit to air dry? What's your technique?
