Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
How To use Nanoskin Autoscrub Pads on Makita BO6040
Step 1: Center and attach the 4" Nanoskin Autoscrub pads to the backing plates on the Makita BO6040
Step 2: Spray panel down liberally using Nanoskin Glide Instant Detail Spray Lubricant
Step 3: Set speed to the 2-3 setting and then place Nanoskin Autoscrub pad against panel and move polisher over paint using medium arm speed with overlapping passes.
Set speed to the 2 to 3 setting...
Spray Nanosking Glide onto panel...
With the Makita BO6040 you can use it in either the Forced Orbital Rotation Mode, (arrow on switch pointing forward), or the Free Spinning Random Orbital Rotation Mode, (Arrow on switch pointing to the back of the tool), it works well either way.
Keep the pad flat to the surface and use a medium arm speed to move the Makita BO6040 over the surface
On Autogeek.net
Nanoskin Car Care Products
On Autogeek.net
