C chasm47 New member Joined Dec 11, 2010 Messages 23 Reaction score 0 Mar 8, 2011 #1 I have some Menzerna 106FA I want to try--don`t have a heated garage--what range of temps does it work best in?
M Mike PhillipsMike Phillips is verified member. Active member Joined Dec 5, 2022 Messages 51,004 Reaction score 7 Mar 8, 2011 #2 Generally speaking, Most paint care product will work best between the temperatures of 60 degrees and 80 degrees. If you want to push the limits then 50 degrees to 90 degrees. When you start getting colder or warmer than this wipe-off and workability will start to become affected. Back in 2004 I wrote a pretty comprehensive article on this over on MOL here. What temperature ranges are best for applying cleaners, polishes, and waxes I'll try to re-write it so I don't plagiarize myself and post it over here...
