Regardless, the paint looks great and my second cyan pad shows virtually no wear, so I think I improved my cleaning technique on day 2.
I’d have to agree with that, your Beemer looks terrific. You’ve done a great job. Your BMW must be close on 15 years old and it sure looks like new again.
On reflection, I think you probably found the brush cleaning technique inadequate because you were using UC. UC tends to saturate a pad after some use and therefore I can probably now see why the brush technique did not work that well for you. I rarely ever use UC as I prefer the speed and the greater cutting power of M105. Typically M105 creates a lot of dust, which many here don’t like, so the dust and the paint residue collect on the pad. Therefore instead of the pad getting saturated as it does with UC, it tends to cake up instead. That is where the brush cleaning technique shines in removing that cake up.
UC does have reasonably good cut, but it is not in the same league of M105, so eventually I’m sure you’ll come across a situation where you will need greater cutting power than UC and move to the M105/M205 combo. After you have made that step, it sort of becomes difficult going back to UC. If you get to try M105, try again with the pad brush.
You’ve probably by now read the other thread by Todd re the HT pads. I sort of think you have fluked it, when you’ve used a damp HT pad. The closed cell design makes these pads very susceptible to retaining moisture. The first time it happened to me I think I was using a Crimson pad which was left to dry overnight on the floor outlet of the central heating as is my normal practice. The pad appeared to be dry, just the same as any other pad, but by the time I’d made a number of passes, I noticed steam (thought it was smoke) coming from the pad. Luckily I noticed it for when I removed the pad from the backing plate it was definitely wet. I’m sure if I had kept going the pad would have just exploded or should that be imploded. Either way I doubt it would have been a good result.
Try the following tip to prolong the life of the Cyan pad. Because it is a delicate pad, have a back up Orange pad (yes I know a few more bucks, you’ll have to spend). Use the Cyan pad for the first couple of passes, but when you come to panels such as doors etc try and avoid the edges of the panel. For instance, avoid the area where the panel joins the window, or around the door handles or any protruding emblem. The really delicate part of the Cyan pad is its edge, so the idea is to avoid using it. After you’ve completed the Cyan pass, now swap to the Orange pad and do the complete panel, including the areas you previously avoided. Orange pads also wear out, but they are a hell of lot tougher than a Cyan pad, so can withstand polishing on an edge.
