Wheelzntoys
- Dec 18, 2011
- 573
Did you try a specific water remover? Some contain Muriatic acid or some other type and made to remove spots (use with caution).
Holy smokes, I have never seen so much water spot in my life. Was this just over night? That's insane.
Yeah, how long were those spots on there? I think some decon acid would have been my first step before any compounding.
Why not try sanding first and then compounding and see if the marks go away? Is it even possible to sue someone if that happens to you? The problem should be fixed by them if they failed to warn you that their sprinklers were bad.
I would try sanding down, just be careful. It's the only last step you can take, it's going to be repainted anyways so might as well try to see if sanding will take off the marks.
If you don't know how to properly sand or need help with it, i'm in Los Angeles as well and can give you a hand.
I might try to give it another shotOuch that hurts! I have never seen spotting that bad before.
Maybe see if someone around you has wool and a rotary to give it one last shot before a re spray?
Only water spots remover I have ever tried was cchemical guys and it didnt work on spots way less severe than thisDid you try a specific water remover? Some contain Muriatic acid or some other type and made to remove spots (use with caution).
Looks like the fine water we have down here, which is often loaded with what they call Caliche here.
These sprinkler systems often use what's referred to as recycled non-potable water.
I know some have suggested sanding, but wouldn't something like a Clay Bar work? I guess it depends on if the water has also actually etched the paint?
A suggestion of some type of acidic wash might help, (How about Kaboom? LOL) but I'd be worried about something like that effecting trim, badges, and other areas of the car.
What machine do you have? Even a 7424xp can take the marks off. You just need to go through a multiple process with the sanding papers. Example starting with 1500 then going with 2000 and then with 2500 and then removing the marks. I can easily remove 1500 marks with my 105 or menzerna SIP. If you are gently, you won't take much clearcoat if you know what you're doing. Since its been only a week, the WM's aren't that deep.
If they are less than one week old, im not sure why they can't be taken off using the machine and a yellow pad and a compound like 105. I would think that pads like surbuf would take them off.
I tend to agree with Mike here and would take it even further. I'd be after those mineral deposits with an acid based wheel cleaner such as Poorboy's World Spray and Rinse or another equivalent product, working in small manageable work sections as to not allow the product to dry on the paint or go down into cracks where it can't be rinsed back out thoroughly. Spray it on, work it with either a brush or a sponge or what have you, then rinse it with lots of water before moving on to the next section.
So many people are so quick to just jump on something like this with heavy abrasives or worse yet start sanding as a first step. I see over and over that the answer to hard water mineral deposits is one of a chemical nature. It's been posted here over and over by many people throughout the years where vinegar (acetic acid) is the first step to softening light mineral deposits before using some sort of polish (preferably a chemical polish) to remove the remaining mineral deposits, then at that point inspect the paint to see what further corrections will be necessary.
Now it's obvious of course by looking at the photos that the OP is not dealing with light mineral deposits, but rather very severe mineral deposits which may or may not have already etched deeply into the paint. So if a light concentration of acid like what's in vinegar will help to soften a light concentration of mineral deposits...raise the level of mineral deposits...raise the level of acid concentration...enter the acid based wheel cleaner which is not a super high concentration of acid, but a high enough concentration to be effective on clear coated wheels without melting off the clear coat or etching deeply into it when used with some common sense and following the directions.
It works on severe wheels and it will also work a severe case of mineral deposits on the painted surfaces of the car...again...if used with the same common sense that which you would use it on a wheel which would be ... make sure the surface is not hot...if it is, then rinse it with cool running water to cool it off or take it into the shade to work on it...spray the acid on in one manageable work area...you wouldn't go and spray all 4 wheels at the same time then take your time with the first wheel as the acid is etching into the other 3 wheels would you? No...you'd do one wheel at a time as to manage the work that the acid does as you mechanically agitate it with a brush before thoroughly rinsing. Agitate with your favorite device of agitation whether it be a brush, towel, wax applicator etc. then rinse before moving on to another section to begin the same process all over again.
Another thing I've found through the process of constantly traveling outside the box in testing different products in different situations that come to me through the years, is that a good metal polish (machine applied with a soft foam finishing pad) will work well at removing the remaining mineral deposits in a non abrasive way, leaving you in the end with a clean paint surface that can then be properly inspected to see if abrasives will be a necessary follow up step.
By taking a chemical approach to a problem like in the OP's photos, you give the clear coat a sporting chance at surviving this debacle. Jumping right in with rocks in a bottle and wool pad with a rotary, or worse yet..."just sand it" destroys any possibility of preserving as much clear coat as possible.
The above is not my opinion, nor is it a guess on my part. It's knowledge from constantly testing different products and procedures in different situations as they come at me. As a professional detailer who wishes to "break the mold" that the larger percentage of the industry has cast, it's my business to know such things.
Just my 2 cents on the subject, hope it helps someone. TD
I tried but it didnt remove them just made them lighter. It left etching behind from the spots. I have remove sanding marks with that combo it didnt work on this
Sent from my SGH-T999 using Tapatalk 2
Wow dave thanks for the great info
Is that in Los Angeles?
The drinking water in Los Angeles is terribe to begin with so I am sure that the water used for irrigation is even worse. I am sure it is some recycled or less refined water especially since it is CA.
Maybe contact one of the Los Angeles detailers like Joe at Superior Shine and see if he has encountered this problem before and if he can offer you any suggestions.
You're quite welcome. Just trying to earn my spot here at the Geek. :xyxthumbs:
Correction. Water spots were there for almost two weeks not 4 days
That's nasty. If I can help you out let me know. I'm in OC. I've got RB, Flex 3401 and PC with a variety of pads wool and foam. I agree with Dave's advise. Try to break down the spotting with chemicals first, clay and buff. I'm pretty sure you can save the paint and not have to respray it.
That car needs to be parked somewhere other in the line of fire.
