Klasse Act
- Feb 21, 2012
- 27,899
- 3,052
- Thread starter
- #161
Are you wanting this just for WW?
You will use it more than you think!
Hmmm, wonder if it's just a battery upgrade?Looks like there is a new model 40v series hydroshot... have not used so cannot comment on it.
https://www.worx.com/40v-share-volt-tools/40v-hydroshot-portable-power-cleaner-wg640.html
Based on the listed specs it goes to 335 max PSI vs the 320 max PSI on the 20v
Checked the spec of the 40V vs 20V. Very similar flow rate and only small increase in the psi for the high power setting...So I highly suspect the 40V version is marketing gimmick.Hmmm, wonder if it's just a battery upgrade?
TWO HUNDRED AND SIXTY SIX DOLLARS for the fast charger, WOW! I will eventually get the 4.0v battery, thus giving me a total of 3 batteries, so I could wash 2 cars in a row if need be.
I'm glad it's serving you well
