I have a few reviews..
01AUDI
I am pretty new to higher end product so take this with a grain of salt but..
Poorboys Natural Stuff - Great Product !! I used this on my entire interior plastics, rubber and even leather. It transformed my interior. I tested a few spots that I had spilled or had some caked on grime.. it cleaned up and finished very nicely. It left a bright but not oily look and the feel was like a Matt finish. It cleaned and helped my leather but I didn't see much dirt on my rags so I'm not sure it was acutely cleaning as much as dressing the leather. I tried it on my tires after the a good cleaning and although it says you can, it didn't do anything for mine. I did apply some to myou exterior rubber and plastics about two weeks ago and you can see a noticeable difference still today after my wash. It was the same as the interior, great cleaning ability and great finish. Defenitley recommend this product, just need something different for leather and tires.
Poor boys APC- I used this on the interior at 15:1 and it was a little strong so I stopped. It left a sticky fealing to the area applied too. I did apply to the tires, stock wheels and fender wells. I had dome trouble with and transmission fluid flying all over my under carrage and this cleaned it up very nice at even at 15:1. It cleaned my wheels great and took all brake dust away and clearned my tires pretty well too. I might go to 10:1 next time fr the tires but it did work very well.
Optimum Car Wax - WOW!!!! This stuff transformed my paint. I am still waiting on a few products in the mail to use my mk360 and do an actual correction but this came in the mail so I had to try ! I've always used Meguiars gold class wax but I have never seen my black paint reflect like this. 2 sprays per large panel and I used it while drying. It did stresk some which I have seen discussed but after it dried I wiped it down with a new towel and all was great. Very Very happy with this product. I will update later on durability, we have rain I the forecast all next week this is perfect timing.
The only product I use on your list is the APC. I've never had any issues with it at any dilution ratio. I have a bottle of 1:1 for heavy grime on stuff like exhaust tips, 1:15-ish for general purposes, and I think 1:20 for leather. It's been a while since I mixed up my bottles.
What type of surface became sticky? I've used the product on all sorts of interior surfaces and never encountered anything like that.
It was the arm rest, which i believe is some type of vinyl, definitely not leather. Maybe that area was always a little faded but it seems like the area is a little blotchy now too. I used it on the plastics all around the dash and even some other vinyl-like areas and they all did fine. It was just the arms that were sticky and blotchy. Maybe, just maybe it is real leather and the ratio was too strong? I didn't even try it on my leather seats so i cant compare there. But it definitely has a sticky feeling to it. I was going to follow it up yesterday with some Natural Look and see if that took the feeling away. I just forgot.
How old is the vinyl on the armrest? How well was it kept in the past.
I've had places like steering wheels and shift knobs get a little sticky in the past, but that was simply because they were really grimy from constant contact with my hands. It took a little extra cleaning to bring them back to being clean and the right feel.
Maybe take a soft damp towel and gently try to clean a less visible area of the armrest to see how much grime is actually coming up.
It is 8 years old so its not new, but after camping it can get a little dirty and built up from the trip and contact from my dirty hands opening and closing the doors. Before i got the Poorboys i had always used an old spray bottle of some Meguiars interior spray. It was more like a coating than a cleaner so i usually wiped everything down with a damp rag using water, then dried and used the Meguiars.
Are you suggesting to wipe it down with a damp rag of water or damp rag with the apc ? I felt like it got a little blotchy and sticky so i stopped and was nervous about making it worse. There isn't much un-noticble area on this panel so i either have to cross my fingers and do it, or try something else ? ha
I am getting a small sample of Griots 3-1 leather cleaner from a person so should i try that first ?
I was suggesting a rag damp with water to play it safe, but it sounds like you've gone that approach in the past. Did the stickiness go away after it dried? If not, I'm at a loss.
i am going to try the damp rag right now. ill give it 10 min or so to completely dry and then ill check.
I have the worst time uploading pictures, sometime they take them sometimes they don't. i don't get it..
either way, the white rag is pretty dirty ! it had definitely pulled up some dirt. I will do the sticky test soon
You have to do it through your smartphone. Download an app called Tapatalk and post pictures that are on your phone. Works everytime guaranteed.
You can easily do it via a browser too. The only limitation is ensuring the pictures are sized correctly, but even then that is an easily solved solution.
I prefer loading the photos to the gallery to ensure I'll always have the pictures stored somewhere I can easily reuse them again. I have picture sizing app I found for free in the Windows App store that resizes them with only a few mouse clicks. I can pull photos from Google Photos, size them and upload them here pretty rapidly.
It doesn’t seem so easy considering how many people give up and aren’t able to post pics on this forum.
On Tapatalk you simply select a photo from your phone and it gives you 3 different sizes to choose, you select the largest 1 and it posts instantly. Doesn’t get any easier than that. No re sizing, cropping, etc. + I haven’t seen my pics disappear.
I wouldn’t even know how to re size a photo...
I forgot to update this.. yes i washed with a damp rag and it actually took the stickiness away! I may be crazy but it doesn't look at blotchy too. Could the APC really do that? It was only on that material, whatever it actually is though.
You mentioned a bit ago the damp rag came back really dirty. Could the blotchy spots have been the result of some areas being cleaner than others and now everything is equal? Glad it's better now.
yea i suppose. I had read something the other day saying to wipe down an area with the APC and then wipe it down after with another rag. I only wiped it down initially with the APC and never "wiped it off" so yea maybe that is what it needed. thanks for that recomendation
I forgot to add this picture.. This was my trim in between the hood and windshield. After sitting outside for years it has turned the awful grey. I added a layer of Poorboys Natural Stuff and wow! This was obviously right after applying but even after drying and a couple weeks later, it still looks a lot better. Not as black as the picture, but much much better! I would love to try out their actual exterior trim product, but if you have natural stuff id go ahead and try this.
https://thumb.ibb.co/moWHDb/tr.jpg
Optimum Car Wax is incredible. Absolutely love that, and Opti-Seal.
