Hi All,
I got a 911 993 and as you might know they have these stoneguards (Sticker) on the rear fenders which get brittle after a while...
- I removed the old brittle stoneguard stickers, which was a huge pain to do... however after many many hours they were finally off and all glue residue was removed!
- I ordered new ones, made from 3M tape and installed them around last August... however it seems I messed up the installation a bit... had some blisters, and some not so nice spots...
- I ordered another pair and thought “hey, I will try again as I kinda know now what I’m doing”
So here we go:
in order to install the new guards I started to remove the ones from the first fender this afternoon... I used my heat gun and pulled in a steep angle... few minutes later, the sticker was gone and just some residue left!
i started using WD40 to get rid of the residue when I realized that most of what looked like residue, was actually damaged clear coat!!!!
you can see on the pictures the “lines” this is clear coat damage!
i love my car, I’m super careful and can’t believe this happened!
Now I’m panicking and see these options which all suck!
1) respray needed of probably entire fender area? Paint was original, so this would ruin the authenticity of the car a bit...
2) is it possible to fill / spray in just some clear, on the area where the sticker was?
3) simply use a black fender guard sticker and hide the damage
4) polish hard... but don’t think this will help...
by the way: besides the clear coat damage, I still have most of the residue on! This glue is crazy! It simply doesn’t wanna come off!
Even worse: the guard on the other side is of course still on, and need to remove it as well... after this experience I’m panicking!
So here we go:
