ClearVue18
- Jan 27, 2018
- 1,091
I've used it for years and never had a issue. There isn't any special remover that isn't harsh to an extent. The PPF was removed improperly. We aren't speaking of dumping a gas can over the paint to remove anything but if you take a pea drop amount on a microfiber it won't damage anything long as you do it gently.Please do not use gasoline... do not wet sand.
How long did you let the Sonax Glue Remover dwell for? After applying a liberal amount, did you let it dwell for 15 minutes or more? Did you try plastic razor blades. From what I'm seeing in the pictures, I'm still thinking this can come off... I removed a partial frontal of clear bra off a Mustang and I will tell you, this isn't a 15 minute job. It was like 4 or 5 hours per section just getting all the aged glue residue off.
I used two full bottles of goo-be-gone, plastic razors, some steam, and a lot of patients and rubbing with micro-fiber towels. I knew paint correction was coming after.
If the dwell time and working at it doesn't resolve the issue, take the vehicle to a place that specializes in Clear-Bra installation. They have some heavy-duty glue removers to remove previous installs of PPF and other products. They may be able to help you. Using harsh chemicals such as gasoline, is first unsafe for your health, environment, it's flambe and highly toxic, and not to mention the worst kind of spill you can get on your paint.
If this is beyond your capabilities and you've tried some of the methods suggested (sans gasoline and wet-sanding) you should take the car to a professional PPF installer for more suggestions.
Here is the glue residue from the fender... It doesn't look much different than the photo you posted:
Before
After:
Before:
After:
Sent from my SM-N960U using Autogeekonline mobile app
