Ill keep it short and sweet, since i will make another post about the entire detail by the end of the week.
Detailed my mom's 2007 Dark Blue Metallic Tahoe. Did a 2 step correction with Menzerna FG400 and SF4000 for the really bad areas like the hood and roof and IS1500 and SF4000 for the rest of the body panels.
At the end of the correction, everything was wiped down thoroughly with CarPro Eraser. Now to the Opti-Coat. I had watched several videos and used the supplied yellow applicator pad to put it on. I noticed in the video most people only used a few drops of the product on the pad to spread onto the paint. I did the "X" across the pad to start, and then used maybe 3 to 6 drops on the pad for subsequent applications. The pad felt very grabby on the paint and squeaked very loudly as i applied it. I had to use a lot of pressure and rotate the pad around frequently to find a spot that would have some more Opti-Coat in it to spread. It seemed to spread on very very thin, and i had very few high spots afterward. Keep in mind this is a very very large vehicle. The picture below showed how much we used on it, which was about 2.5cc. During the final inspection, about 30 minutes after the Opti-Coat had completely flashed and no signs of it were left, there were several spots that seemed a bit hazy. I took a Chinchilla buffing cloth and rubbed on them with moderate pressure and most all of them went away. Not sure wether that was from having an underlubricated application pad and maybe scuffed the paint with a small dust particle or what.
My concerns:
1. Should i be worried that not enough Opti-Coat was used and I will not get the desired results?
2. Is it bad that I buffed over the surface of the entire vehicle with a Chinchilla within 30 minutes of application?
3. Should I pull it out in a few days and spray water onto it and note that it isnt completely protected, would i still need to polish the paint again to remove what little Opti-Coat is there, or can i go ahead and apply a second, thicker coat of the Opti-Coat over the entire vehicle?
Sorry for the noob questions. It looked easy online, but apparently I didnt read enough about it when it came to how much to actually use.
My concerns:
