Ok, so if you could do it all over again, knowing what you know now, what advice would you give me?
This will by my first time every doing anything like this. I took all your great advice so far, and gathered all the appropriate gear and juices, I am now ready to tackle the beast of a project I have for my black Acura RL. This car’s paint is hurting, I attached a couple pictures. I drive it all day long as a real estate agent, having clients climb in and out of it, so I need it looking top notch, and well protected.
Boy do I hope this is overspray or just straight up contaminates...
Another shot of it...
A few questions I have straight out the gate is :
How much waterless wash should I use? Enough to have it start dripping down? Or just enough to mist the paint?
With the Wet Diamond All Finish Paint Protection and Collinite, do I Orbital up the whole car, then buff it down? Or work in sections, Orbital a small section, then buff?
Any advantage of leaving the Wet Diamond on for 24 hours before I buff it down? Or would it be best to buff it down, then let it cure?
Any products you would swap with something else? Or add into the mix? Like Iron X?
My plan is :
1. Wash it down real good [DP Waterless Auto Wash
2. Clay down the car and windows [Pinnacle Ultra Poly Clay / Pinnacle Clay Lubricant]
3. Wash down car again [DP Waterless Auto Wash]
4. Tape off exposed rubber frame around sunroof, emblems and badges, and other seams where I have already found remnants of “other people’s wax” [Green 3m auto performance masking tape”
5. With a 6inch Griot’s Random Orbital & Orange LCC Flat Pad – Polish car in small sections, then buff areas before starting new section – [Wolfgang Total Swirl Remover]
6. With the Orbital & White LCC Flat Pad – Glaze car in small sections, then buff area before starting new section [Wolfgang Finishing Glaze]
7. With the Orbital & Crimson LCC Pad – Seal Paint [Blackfire Wet Diamond All Finish Paint Protection]
**Let cure in garage for 24 hours**
8. With the Orbital & Different Crimson LCC Pad – Wax entire car down [Collinite’s 845]
9. Remove tape and clean windows – [Stoner and Waffle Weave Towel]
Thank you again for all your help and advice!!!!
My plan is :
