snowracer21
- Jul 21, 2018
- 35
I've been interested in a few of the IK sprayers for quite some time now.
One thing I quickly learned when I branched out into for-profit detailing is: a good spray bottle is worth its weight in gold. I can't stand leaky caps, poor spray performance, and failures in the middle of a job. I scrapped my old $1 generic spray bottles and replaced them w/ Kwazar dual action sprayers. Night & day difference!
I'm one of those types who would rather pay more for a higher performing product rather than a cheaper alternative and sacrificing performance. Always been that way whether it's power tools, performance parts, etc.
I currently utilize these, which I picked on on Amazon for about $10 per:
They seem to work just fine, not sure on durability as I've only owned them for about 6 months... the spray velocity is not anything special, and the carrying handle is quite flimsy...but it's $10.
I use these pump sprayers for:
I find that pump sprayers like the one I posted above are much more efficient to spread a lot of product quickly e.g. soaking wheels/tires for cleaning, spraying down the front grill of a truck to remove bugs, spraying wheel wells of pickup trucks with APC, etc.
I'm always trying to discover new and better/more efficient ways to work. I believe the IK Foam 9 sprayer would work very well at getting cleaners/degreasers in difficult to reach areas (wheel wells/suspension), and doing so while not having to crouch/kneel down. A few less times bending over, and a few minutes saved per detail will add up over time.
One question I had though:
What is the advantage of foaming the product? If I had Optimum Power Clean in an IK Foamer, would it do an even better job at cutting through grime than just a normal sprayer? What about wheel cleaners? I probably wouldn't use it for pre soaking prior to wash, as I already have a pressure washer and foam cannon.
Looking to hear what you guys have to say!
- Meguiar's Wheel Brightener
- Optimum Power Clean
- McKee's 37 Bug Remover
- ONR 16:1 clay lube
