Ink on interior plastic
JohnF
I valeted my new Explorer at my sis's wedding this weekend and the driver dragged his pen across the center console and door panel in two small places leaving a couple of blue pen marks on my tan interior. I didn't notice until I was on my way home this morning.
I've tried a few methods to remove the ink but haven't found a solution.
I have tried,
mothers carpet & upholstry cleaner with a micro.
mothers back to black with an interior brush
mothers leather cleaner with a micro
and hair spray with a micro.
No luck yet & I'm tapped out of ideas
Anyone?
Wd-40 ?? Goof Off (water based formula) ?? Just remember to redress with protectant as possible.
Just did the wife's interior this afternoon, only to discover that our 5 year daughter wrote on the tan door panel ( plastic/vinyl). Tried a few upholstery cleaners. Nothing made even a slight dent. Was wondering if wd-40 or goof off has worked for anyone, or has anyone found something that will remove or lighten the ink. Thanks inadvance.
I haven't had a need to use it but a year or so ago I bought Magna Mark, Professional Ink Remover. I seem to recall I got it from ADS. The only precaution is to not use it on non-topcoated leathers such as suede, nubuck, kid glove, pigskin and rawhide.
I just saw the reply mentioning Magic Eraser. It works but use with care and a very light touch. I can and will remove a color coating on vinyl and can harm leather.
Aqua Net hairspray can be used to take ink out of clothes so I cannot see why it wouldn't work on plastic. I would just go over it with a interior cleaner after taking the ink out.
I've never tried it but I have read about using Aqua Net Hair Spray for years... Aqua Net or any hair spray may no longer work like it used to since like so many products, hair sprays have been reformulated to meet stricter V.O.C. regulations.
From Wikipedia
Hair spray (also hair lacquer, spritz, or sticky water) is a common household aqueous solution that is used to keep hair stiff or in a certain style. Stronger than hair gel or hair wax, it is sprayed to hold styles for a long period. Using a pump or aerosol spray nozzle, it sprays evenly over the hair. May leave hair feeling "crunchy" unless brushed out. Hair spray was first developed and manufactured in 1948 by Chase Products Company, based in Broadview, Illinois.
The solvent used was once a compound of carbon, fluorine, and chlorine (a chlorofluorocarbon, or CFC). CFCs are nontoxic, nonflammable, and make almost ideal aerosol propellants. However, when it was learned that they cause destruction of stratospheric ozone, they were replaced with other solvents, like alcohols and hydrocarbons.
One of the polymers used is polyvinylpyrrolidone, which is also used to glue the layers of wood in plywood together. A non-water soluble polymer called polydimethylsiloxane is added to make the hold last a bit longer (the polyvinylpyrrolidine is water soluble). Pytocalcious chemicals are another family of ingredients in hair spray, which increase the amount of minerals in the hair's root causing the hair to become stiff.
Other polymers used in plastic-based hairsprays are copolymers with vinyl acetate and copolymers with maleic anhydride.
Some hair sprays use natural polymers and solvents like vegetable gums dissolved in alcohol. One popular ingedient is gum arabic is made from the sap of certain trees that grow in the Sudan. Gum tragacanth is another herbal gum that is used to stiffen calico and crepe, as well as hair.
Japanese scientists have recently found strains of bacteria, Microbacterium hatanonis, that have evolved to live in hair spray.[1]
I would strongly recommend testing products specifically formulated for removing ink versus household urban myth type products...
And as always, test in an inconspicuous area first... (when possible)
Send it to the uphoulstery shop and send numbnuts the bill. Your not going to be able to remove this without re-dyeing IMO
