Interior detailer + ONR clay question
getgoing
Hi guys,
I have some questions if someone can please guide me. I am a newbie.
1. What's a good interior detailing/cleaning product. I already have Tuff Stuff for my seats. I'd like a little shine.
"Chemical Guys Total Interior" has good Amazon reviews, but I don't think it leaves any shine (which I want).
2. I have Optimum No Rinse and Aero Cosmetics Wash Wax All. After using either of them, can I use Mothers clay bar? If so, should I use the Mothers Instant Detailer that came with the clay bar - or should I use more of ONR or Wash Wax All as the lubricant?
There is a video on Youtube where a guy from Optimum uses ONR and then uses a clay towel with Optimum Car Wax. But I'd like to know if I can use a clay bar.
3. If clay bar is okay to do after a rinseless/waterless wash, as a next step, should I use "CarPro Eraser" before the last step of wax?
4. After doing ONR (and clay), if I just use either Chemical Guys Butter Wet Wax or Collinite 845 - is that enough? Or should I use a separate sealant as well? If so, which one please?
Thanks for any guidance guys!
1- I have no suggestions for shiny products. You'll find that most of us here want products that don't add any shine.
2- Use the Mothers detailer that came with the clay. When you run out of that, it's ok to mix ONR as clay lube and use that.
3- You can use Eraser before the wax but it's not a must, if the car is clean and dry you're ready to apply the wax.
4- Applying just the wax is enough if that's what you want to do. Keep in mind most waxes last weeks instead of months like a sealant would. You can layer both, so apply a sealant like Jescar Powerlock+ and top it with Collinite 845. That combo should last about 6 months.
I would not clay a vehicle that is not going to be polished. Claying, especially done by someone with less experience, will get the paint marred and looking worse (though smooth) and then that has to be polished to look good again before applying a sealant/wax.
Dear Bruno,
Thanks for willing to help.
1. Can you recommend a non-shiny product then please?
(I was looking at Griots and they have two products, "Interior Cleaner" and "Interior Detailer", but I am confused which one I need. I only mentioned this brand as an example. I'm guessing Cleaner means the same thing as All-purpose-cleaner?)
I am not familiar with polish products, can you recommend something please? That I can apply with just a microfiber towel or applicator.
So you are recommending Clay ->Polish -> Eraser -> Sealant/Wax? Or does Polish come after Eraser?
If you would like shine for the interior, I would suggest Meguiar's Ultimate Interior Detailer. It leaves behind a glossy finish. I wouldn't recommend using it on the dash because it can be too shiny and cause glare on your windshield.
Meguiars Ultimate Interior Detailer
My favorite for interior cleaning is McKee’s 37 FAST Interior Detailer but I bet the Griots product would also work well.
There are many polishes out there but I don’t think you’ll have a lot of good results doing it by hand. Are you willing to spend a few hundred on a machine and pads? If not I’d be more inclined to just skip clay and go straight to your wax. Eraser really isn’t a big deal if you’re not doing a coating, if you haven’t purchased that yet, save your money.
Have you tried the baggie test to see if the paint actually needs the clay?
The Baggie Test - How to inspect for above surface bonded contaminants
Is it just me, or is the McKee’s Fasf Interior Detailer slightly grabby compared to Megs Quik Interior Detailer? I’ve only used it once so far and it might’ve been due to the towels I was using [Kirklands] but holy crap that’s the major con that stood out as far as 1st impression.
My bottle of Megs QID stinks like vinegar, but boy does it make for smooth wipedowns while providing adequate cleaning ability.
Hmm I'm never experienced that personally. It's absolutely one if not my number one favorite interior cleaner/detailer.
Sent from my SM-G975U using Autogeekonline mobile app
It’s bugging me that I don’t know where a single 1 of my once large batch of Megs Supreme Shine microfibers are... Like how did they all completely disappear? Lol.
It’s gotta be the Kirklands then.. I’m going to test it again right now.
Very possible. I've never used any of the Kirkland towels before. I typically use the Rag Company Edgeless 245s for interior wipe downs and they've given me no issues.
Towels can definitely make a difference. I remember the first time I used N 914 as a WW and I despised it, it was crazy grabby. Starting using TRC pluffles and it makes the process so much better and since then it's been the only WW product I use.
Disregard my previous comment about Fast Interior Detailer being grabby... 2nd try seemed fine enough as far as that aspect + it passed with flying colors as far as cleaning ability for it’s intended purpose.
I tried to only use 1 side of the towel, but it just kept on cleaning. Lol.
This stuff smells alot like Eternity cologne, which also happens to be my all time favorite go to stuff.
P.s. I would’ve done a side by side half interior test between both interior detailers, but I’m dropping my car off at the dealer tomorrow morning and didn’t want to risk having it smell like vinegar..
Glad to see you had more success. Such a good product and it smells amazing.
I’ll chime in since I’ve used both the Griot’s products. The Interior Detailer is one of my favorites. The idea of an interior detailer vs a cleaner is just that a detailer is designed to do mild cleaning and leaves a lil something behind; an interior cleaner packs more cleaning power and leaves no protection. An interior cleaner (to me) is generally safer than an all purpose cleaner because you don’t have to worry about a dilution ratio, and it’s a tested product made for your purpose. If your interior’s not stained, the Interior Detailer works just fine for even moderate clean-up in my experience.
I’ve also used the Over The Counter Meguiars Interior Detailer; to me it worked functionally the same as the Griot’s product. I like the smell of the Griot’s stuff better.
Hi guys,
I need some help. I've never personally detailed my car, so everything here (brands, products, terminology) is completely new to me. I've spent many hours reading and educating myself, but the vast number of categories is overwhelming.
I found the following products and categories from a video by "Pan TheOrganizer":
1. Best quick detailers:
Optimum Car Wax
Turtle Wax ICE Spray Wax
Griot’s Garage Best of Show Detailer
2. Best APC + cleaner-degreasers:
CarPro MultiX
Super Clean
Meguiar’s Super Degreaser
Meguiar APC
3. Best interior cleaners:
CarPro Inside
Chemical Guys Inner Clean
P&S Interior Cleaner
ONR
4. Best interior dressing/protectant:
CarPro PERL
303 Aerospace Protectant
Chemical Guys Silk Shine
Can someone help reduce these 4 categories to the most essential please? And tell me which of these products are most necessary - for exterior and interior detail.
Thanks
Optimum Car Wax
That information is completely wrong.
How in the world can Optimum Car Wax even be in the discussion, let alone be the #1 Quick Detailer if it isn’t even a “quick detailer”? Same goes for Turtle Wax Spray Wax... My goodness how can people get things so absolutely wrong while supposedly “teaching” others how to do... Smh.
As far as your entire question, I’m sorry I don’t have enough time to fully answer it right now, but I’m sure someone will be able to help you out shortly...
Hi guys,
Welcome to AGO. :)
Your reading up on everything is exactly how I started. Read, read, read!
To make it a bit easier for you, try and ask questions about specific products for specific tasks. (e.g.: "What do you guys think is the best QD for metallic paint?") Asking questions about large groups of products will most always result in guys/girls not replying due the time it takes for a full, informative answer.
Singular questions will get you a ton more replies, but you still must make the final decision for yourself. But you might find a few pros/cons in the replies to help you decide.
And, you can always PM a member with specific questions. We are here to help. :)
Hi guys,
Optimum Car Wax
CarPro MultiX
Super Clean
Meguiar APC
CarPro Inside
ONR
CarPro PERL
Thanks
1.
Best quick detailer would be for me Meguiars Ceramic Detailer. For me though for the price i like a waterless wash concentrate better and will add a prduct if i need protection. I like Car Pros Ech20 best in this case.
Griots BOSS quick detailer and Speed Shine also are honorable mentions.
2.
I use super clean and LATA but when out will go with Meguiars. Gets most overall positive reviews
3.
I like Car Pros inside for deeper cleaning of dirty cars. I personally use Meguiars quik interior detailer most but just bought a gallon of the P&S due to all the stellar reviews, P&S’s track record and price. Paid $12 dollars for a gallon.
4.
PERL is nice but doesn’t last long. I like 303 because i get 2-4 months even when my top is down and I like that it lasts long
I found I had the best results when I ditched the spray bottle. I have a container I put some product in and then just immerse the MF and ring out (Kind of Gary Dean method). Just a wipe down for a maintained vehicle (But, that's the only time I would use this type of product anyway.) One or two rags - it's quick and doesn't really use much product. McKee's Fast Detailer is good stuff.
Interesting, never would’ve thought of doing it that way... But how do you get every surface fully dry if you’re working with the towels that damp?
I thought the same the first time I was going to do it. I thought if i wrung it out too much it would go dry on me and I didn't want it so wet that I would have to follow up with a dry MF. I can't convey to you how much I wrung it out. You just have to work with it. The product isn't that finicky that you have to leave the perfect amount on the MF. It worked well.
So you just keep a bucket year round on the shelf with a fair amount of Fast Interior Detailer? I can’t imagine you ever dump it out, right?
