Interior Detailing - 2 Tips and 2 Tools - SCANGRIP I-View and Tornador ZV-240 Velocity Vac Dry by Mike Phillips
Here's 2 tips and two cool tools to help you reduce your interior detailing time while doing a better job.
SCANGRIP I-View
The Tornador ZV-240 Velocity Vac Dry is a powerful cleaning tool that works of the suction from your shop-vac and the compressed air from your air compressor.
How it works
It blasts a tornado or circular pattern of high pressure air at the surface blowing out debris while at the same time extracting the debris into your shop-vac. This is definitely one tool you have to see to believe or take my word for it - it's amazing!
The SCANGRIP I-View is an interior detailer's best friend. It completely lights up the interior area you're cleaning so for once!!! you can actually see what you're doing.
Together these two tools make for the Dynamic Duo!
On Autogeek.com
SCANGRIP I-View
Continued....
Interior Detailing
Cleaning the inside of your car is for the most part a mundane chore that's not very fun or exciting to say the least. Cleaning the interior of someone else's car is even less fun and exciting except if you're detailing for a business at least there's a financial reward at the end of the day.
Here's two tips to make interior detailing faster and easier.
1: Before vacuuming out the interior, slide the seats to either the extreme forward position or the extreme rear position. By doing this you'll expose the maximu floor space on one side of the seat to make it easier to remove all debris and vacuum thoroughly.
2: Before vacuuming, after moving the seats either forward or to the rear of the car, next take and blow out the underneath of the seat using one of these tools,
Air blowing tools
Tornador Blow Out Gun
Metro Blaster SideKick
Metro Master Blaster 8hp Revolution with 30 foot hose
By blowing all the gum wrappers, old dried out French fires, kids toys, hair ties under the seat to either the front of the back portion of the car you'll make it easier to remove and vacuum all this junk out of the car enableing you to do a more thorough job.
Continued...
Now lets put all these tools to work and clean an car interior... the victim here is a 2004 Acura TSX 4-door that we used for exterior detailing, headlight correction at my last 3-day detailing class. We used other cars for interiror detailing so before returing the car back to the owner with clean exterior I saved it for some new product review.
There's a pretty good film on the inside of the glass, this oily film is called vinyl fog and it's also just normal accumulation of gunk from normal use.
Photography lamp
Besides using the SCANGRIP Sunmatch Swirl Finder Light to find swirls I also use it to light up shots when I'm taking pictures for articles. The full color spectrum light emitted by this tool works great for photography work including taking pictures of the inside of a car.
This Acura has both vinyl and leather surfaces and everything is dirty from neglect over the years.
I'll be cleaning and bringing the vinyl in this car back to life with the new GYEON Vinyl Cleaner and GYEON Q2M Preserve.
Use only water and a microfiber towel?
Look at these seats...
Water only? - What?
Once in a while I see some well-meaning person tell others that,
Modern leather is coated, you don't need special products to clean, condition or protect modern coated leather. Simply wipe using a microfiber towel and some water.
Really?
These seats look dull and lifeless, even ugly. Wiping them with some water will do nothing. Zero. Zilch. You'll see these pictures in an upcoming review of GYEON Leather Cleaner and GYEON Leather Coat Q2.
The floors including both the floor mats and the floor carpeting
Dusty and dirty...
Shifter and center console are due for a little cleaning....
If the seats, dash, console and floor is dirt my guess is the door panels are dirty too....
Continued...
First remove all the larger clutter and debris that's too large to vacuum...
After you've removed all the large debris you can see, next move the seats to either the extreme forward or rearward position...
Next - blow out the underneath of the seat using a air tool like the Tornador Air Blow Out Gun
After blowing all the junk under the seat forward, carefully lift out the floor mat. It's easier to dump the dirt on the floor matt off than it is to vacuum it out of the carpet so that's why I blow out the seats first and then remove the mats but if you want you can remove the mats first and blow all the junk out onto the carpet and then vacuum the carpet.
Vacuum out the dirt and debris with your shop-vac
The SCANGRIP I-Beam
This is the coolest tool for doing interior work. With this lamp on your forehead you can completely light of the area youj're working instead of straining your eyes to see into the dark.
After vacuuming you can use the Tornador Air Blow Out Gun to blast out dirt and debris you couldn't reach with the vacuum.
This is another cool tool, the Tornador ZV-240 Velocity Vac Dry
Repeat this process to the front and back of both sides...
The SCANGRIP I-BEAM really works great to LIGHT UP your work area!
That carpet is clean enough to eat off of! But don't! I don't want you to get any crumbs on that carpet - I did just clean it after all... :)
Your new favorite interior cleaning tool....
The SCANGRIP I-BEAM even works great to light up the trunk!
Ambient light from the overhead florescent lights....
Light from the SCANGRIP I-BEAM!
The Tornador ZV-240 Velocity Vac Dry cleans like a son-of-a-gun...
Continued....
Clean the floor mats before re-installing
You can do this before you clean the interior so they have plenty of time to dry.
Place mats outside...
Spray down with your favorite all-purpose-cleaner...
Scrub with your favorite brush with an extendable handle....
Blast off the cleaner and all the gooey junk it loosened....
After the mats have dried and you've finished cleaning the entire interior, do a final inspection of the carpet and re-install the mats.
NOTE: For safety reasons, NEVER apply a dressing to floor mats or pedals.
And that's about as exciting as I can make cleaning the floors of a 2004 Acura TSX!
On Autogeek.com
SCANGRIP I-View
SONAX Multi Star All Purpose Cleaner
Great job Mike! A buddy of mine bought that tornador tool and loves it.
curious to see for other users if they vac's performance matches the price tag. I probably have more wasted time vacuuming than anything, so I'd love something that would cut down the time there
Sent from my SM-G920V using Tapatalk
I would love to see how the tornador performs on the rolling landfills that so many detailers have to deal with. Can it get dog fur and sand out of crappy carpet? I can't imagine all the hours and aches that would alleviate.
agreed.
Great write up Mike. I agree the I-view is a great light for interiors.
It's good to see this vac attachment come back to life.
Sent from my Pixel using Tapatalk
I did a review of the wet version of the Tornador vac tool. I'm a big fan of the Tornador black but they missed the mark with that. Maybe the vac is better for its intended purpose but the shear size of the contraption makes it more of a hindrance inside the tight confines of a vehicle. I originally wanted it to remove the sand I deal with here in FL, but honestly my metro vac coupled with a sander seems to do a better job. The light looks good but the price tag would hold me back. I have the claw light bar which puts out some good light but the design will not easily attach to most cars. I'm eye balling the hand held scan grip now.
I agree. Cleaning dirty interiors is hard, time consuming and too often gross.
ANYTHING that makes it easier and faster is a welcome advance. As for gross... about all you can do for that is wear gloves and a mask or send the customer to your buddy.
Every detailer should have a "buddy" they can send work they don't want to.
After reading your comment and your question, I'll try to find something with dog fur and sand and put this tool to the test.
The Acura was filled with dried leaves and normal accumulated junk but I think I perfected my technique for using this tool and it's not slow, overlapping passes, it's fast and furious move the opening of the vacuum attatchment around and just get-r-done.
What a way to get "paint guys" interested in interiors... Make cool toys to play with!
Awesome write-up Mike! I love my Tornador Black.
Yeah... sorry about that...
It is the BOMB!
Here's the deal though from a personal perspective...
When doing this type of work I get sweaty including my forehead so I don't think I would want to share my SCANGRIP I-Beam. Sharing it with other people would turn the I-beam into the
Disease Transfer Device
So each person needs to have their own or there would have to be some sort of sanitary cover for where the back rests against your forehead.
That's just my take but I'm kind of a germ-a-phobic mostly because I hate getting sick.
I LOVE MINE!
Lights up nicely.
I used it for all my interiors.
I think you initially shared how well this tool works for interiors with me and that led me to using it for this and what I found out is you're right.
"You couldn't pay me to detail an interior with out the SCANGRIP I-BEAM headlamp"
And yes, you can quote me on that... :)
Where would you improve it?
I'm sending the link to this thread to Dennis Dehn at Tornador, so he'll see all our feedback.
Yes it is kind of bulky or awkward but the way I came over this was to vacuum with it first to remove as much stuff as I could and then RE-BLOW around tight areas using the Blow Out Gun and then vacuum again and yes this took time but it also removed 99.9% of everything.
See this picture,
After vacuuming I then blew out all the dirt behind the base of the gas pedal and the after blowing everything out into the open vacuumed again.
Both approaches will work. The I-Beam removes all the fumbling around with placing the claw light in position and it moves with you but whatever works best for each person is all that matters.
I use this light so much... I use it for
  • Looking for defects
  • Making sure I removed defects
  • Looking for product smears after the job
  • Lighting up "things" before taking a picture
  • Marketing
  • Removing and replacing the engine in my 1987 Chevy Silverado. (Just did that over the course of the last few weeks)
It's handy and the battery charge lasts a long time.
