Great Work Dennis!
I regularly mix a batch of this stuff, & keep it in the bathroom, & spritz the shower, if the smell is overpowering close the door & turn the bathroom fan on 10 - 15 min. No smell, no mold!
Truly amazing tweak the pH slightly, of bleach with vinegar, and you can kill up to & including anthrax spores!
Note: If you see mold, DO NOT DISTURB it (scrubbing etc), you just spread it. Spritz it with the above & spritz a wide area, around the mold, walk away, 30 min repeat. Wash gently, with limp/weak stream of water, down the drain.
I do not believe the above concoction, will stain, fabric, or harm leather.
Test area extremely important. Then treat normally, clean or condition.
The above quote is from a testing lab, submitted by a microbiologist.
I also keep a spritzer in the kitchen, for spraying counter tops, cutting boards etc etc.
Full article here:
Vinegar increases killing power of bleach | EurekAlert! Science News
Test before attacking a whole interior, inconspicuous area FIRST!!!!
You Do not want to prolong breathing in this environment "STRONG SMELL" spritz & go. Or test area, spritz & go. Keep in mind if you saturate an area, it will take longer, for the smell, to be gone, but your more assured of TOTAL mold spore removal.
Mold & mold spores are very tough, to kill, they survive years in nature, & harsh conditions, & still can reproduce. So this is very strong stuff. Spritz & GO!
