-Unless the original container was 100% IPA...Is diluted IPA OK in PVC type plastic spray bottle for the long term? Or should I really use HDPE such as it originally came in?
-IPA is not going to decompose on you, so the only worry (if any) is the permeability of the plastic containers.
Over a long time, you may lose some small amount leaking through the plastic, or possibly dissolving a little of the plastic into solution.
What you are referring to is what we would call 'panelling' - a solvent permeates through the plastic and causes deformation, as partial result. In actual practice, this won't happen with IPA. It is a concern with hydrocarbon solvents which will often do damage to HDPE (though it can be treated to give a barrier to the solvent).
How did IPA get such a reputation for being nasty? From my point of view, it is one of the least nasty solvents about in car care!
If you would put it in a secondary glass-container;Thanks guy's for the feedback! Thought I'd better ask. Had reservations about the
secondary bottle I was putting it in.
