I am surprised that Meguiars doesn't have a competing product to IronX, or do they? CG has one, Optimum has one. Does Megs have one?
6 Yr Old Vehicle No Iron Anywhere According TO McKee Iron Removal and Sonax Wheel Cleaner Full Effect ? My truck is 6 yrs old and never been decon'd and both product did not show any iron even on wheel's . I don't clean it that well.
Anyone else ever had this to happen or maybe bad product? Maybe 1 but both ?
Thoughts , Shares.
Thoughts , Shares.
Thoughts , Shares.
Thanks for the replies and info.Guess i got caught up watching some of these videos and the forum and was expecting a big result like the others say they got.I put the Mckees and the Sonax on my wifes car today and I got a litttle color on the wheels after a good wait and it was warmer today as well .I dont know if temp has a thing to do with it but that is all that was different besides the vehicle.I dont detail professionally and when you buy the good stuff it gets exspensive and you expect it to work ya know.
Thanks again guys for the replies.
I challenge anyone to find a video on youtube that has someone claying their wheels and shows an extreme level of contaminants on the clay. [and I mean that clay better be coated yellow/brown after just a small section of the wheel] Never in my life have I ever seen that happen, in real life or on the internet.
Didn't Larry from AMMO NYC do a video of just that?
Edit: Here is the video:
This is of course taking things to the extreme so take it as you will.
Whilst the forensic detailing video was interesting, the guy doing it is not a chemist and I recall several questionable bits of technical info.
The reality is that the purple compound you see is always the same, irrelevant of the product. Depending on the initial form of the active ingredient, the behaviour will differ. As example, iron-x will be far slower to dry out than an equivalently strong product using a different form. The vast majority use the very cheapest form of the active and are prone to this - it surprises me that every last review neglects to discuss this, especially when discussing a product which slowly dissolved a contaminant and thus where an increased contact time really matters.
Beyond the form of the active, the concentration varies dramatically. Iron-x, for example, has been right at the top end. You can go stronger but it would be labelled as toxic. I have seen products with only a quarter of the level of active and this can go a long way to explain some of the cheaper products. Consider that the key active is probably responsible for 80% of the material cost and you can see why some cut the levels. In reality, you could dilute iron-x and other strong products, perhaps more than 50% and still be stronger than he cheaper options. I bet they won’t seem such bargains now!
Then we have the ‘other’ bits. This will be more pertinent to wheel cleaning than fallout. A wheel cleaner has to actually clean, as well as jus dissolve iron, because wheel soil is much more than brake dust! So this always needs kept in mind.
We then have to consider how strong you actually need the product to be. In our experience, most applications don’t need the maximum strength possible. If you want the absolute best job, more is probably better but you loose less than you might think when dropping the strength. This is especially the case with wheel cleaning. Many people just spray it onto a filthy wheel - this is a bit like settling a $20 bill on fire. The same people focus on the speed and degree of colour change to assess product quality. With so much iron about, you can get away with less active and still get a massive bleed. Annoyingly, some better formulated products will come out worse in this test because they don’t run about everywhere and can thus appear to work more slowly and make less of a purple mess. So you don’t need a great product, especially for mass market. Even with fallout removal, if the contamination isn’t extreme, you don’t need the massive strength.
Personally, I think that 90% of the products I see could have their performance easily boosted. Most dry out faster than they need and many fail to get a consistency which makes it easy to get an even spread, without excessive dripping. If I were choosing, I’d be wanting to get a product which sprays and clings and which gives you as long a working time as possible. At this point you have given the active ingredient the least work to do and maximised your chances of a good result.
Is the bleeding chemical not the chemical that does the desolveing part of the oxidized iron particals? But it's another chemical that does the desolveing part of the oxidized iron particals?
I'm agree with you that it's the clinging part that is the most effective part. And sure it's has to be some kind of minimum active chemical that has the ability to desolve the oxidized iron particals during it's clinging time.
When it's comes to the bleeding wheel cleaners how effective would they be at desolve iron particals on the cars paint in general? In comparison to iron removers.
Chemical Guys Iron Decon does not work well for me.
