Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Iron X Bleeding Effect While Cleaning Brake Dust Off Wheel
Dave parks his truck outside 24 hours a day, 7 days a week and he's not really into the appearance" aspect of car maintenance. He's a heck of a great welder just not much of a detailer...
[ame=http://www.youtube.com/watch?v=Qc5FU_mlQa8&hd=1]Iron X Bleeding Effect While Cleaning Brake Dust Off Wheel - YouTube[/video]
To me this is one of the most important procedures you can do to anything painted as it dissolves the iron particles out of the paint which prevents them from causing the paint to deteriorate.
As it relates to painted body panels on a car...
I've seen first hand the scratching inflicted into car paint when iron particles were in fact removed by claying. The clay removed the iron particles but because you're rubbing the clay over the paint during the process you can't help but to rub the iron particles over the paint and this is where the scratching comes from.
Then of course you have to machine compound the paint to remove the scratches. This removes paint and paint is already thin to start with. So it makes sense to dissolve the iron particles FIRST and then clay the paint.
Iron X isn't a replacement for tools like clay or the Speed Prep Towel for removing above surface bonded contaminants but instead is the a step you want to perform before claying.
Car Insurance
This is key, IronX is like Car Insurance. Car Insurance is a necessary evil. It's something you want to have but you never want to use it.
IronX products are the same way, you don't want to have iron contamination on your wheels or your painted body panels, but if you do have this type of contamination you want to remove it.
So if you spray IronX onto your wheels or body panels and don't see the bleeding-effect, don't feel let down, that's actually a good sign.
The IronX bleeding effect is like water beading,
It looks cool...
And it's intriguing to watch. But if you think about the ramifications of what seeing the bleeding effect means, it's not a good thing and thus you really don't want to see it.
Make sense?
I also share that in this article on how to wash your car. If you read the article, not simply scan it, you'll find the pertinent portion.
How to wash your car KISS style!
KISS stands for Keep it Simple Simon
Look for the text before and after this picture...
On Autogeek.net
CarPro IronX Products
Car Insurance
It looks cool...
Make sense?
On Autogeek.net
